![]() Drives: 2017 camaro ss fifty A8 Join Date: May 2020
Best blower cam with some chop
The performance shop I usually go to recommend the tsp VVT3 to me what’s your guys opinion and how often will I need to check valve springs also what lifters do you recommend
#2 | |
![]() Drives: '20 ZL1 1LE Shadow Grey Metallic Join Date: Jun 2020
Cold start. Start around 1:00 after it begins to warmup https://www.disputesinconstruction.c...2/exhaust3.mp4 ,
OEM short block
HPE custom cam, valve train, and heads FII blower spacer plates & thermal reduction blanket Kong ported blower/snout NW 103mm ported TB Griptec snout pulley ( 2.4) MMS catch can, mild DSX low side pump Kooks Long tubes and Hi-flow cats Custom heat exchangers, RotoFab Remote tuned/ no dyno # yet Tires: Street - Michelin Pilot Sport 4S; Track - Goodyear Eagle F1 Supercar 3R |
#3 | |
![]() Drives: Turbo 6.2 Join Date: Feb 2019
I have a Vengeance Racing stage 2 blower cam. $150 bucks.
https://www.camaro6.com/forums/showthread.php?t=586465 It came out of this car.
2016 Turbo Camaro - 808hp/856tq
2018 LTZ Z71 Redline Silverado - 381hp/420tq |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1SS NFG A8 Join Date: Aug 2017
Hit up Pray Performance for his supercharger cam.
2016 NGM 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/LT5 TB/Rotofab Big Gulp/E60/Cat Deletes/NPP Axle back Perf. times- 1.75 60ft 10.5 @135 1/4mi Dragy Approved...No prep Full weight on 20's. |
#5 | |
![]() ![]() Drives: 2016 Camaro SS Join Date: Sep 2018
This is my GPI blower cam that I am using on a twin turbo set up and it still made 900 rwhp on only 16 pounds even though it isn't ideal for turbos.
This is a cold start: https://youtu.be/Iljyq18YlRM?t=559 And this warm idle. |
#6 | ||
#7 |
It is a custom cam from them, I filled out the cam sheet and told them what I wanted and they made me one. I told them I wanted it to sound nasty at idle. Also keep in mind the sound is being muffled a little by the turbos so it isn't as loud as it would be with headers.
#8 |
#9 |
![]() ![]() ![]() ![]() Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
I like my JRE spec TSP smooth idle blower cam. Just a little nastier idle than stock but similar power to high overlap high chop cams. Lots more fun catching Mustangs, Hellcats, Porches, etc. By surprise!
Baby Blue
2016 Hyper Blue 2SS/6m/MRC/NPP/Silver Rally stripes/ZL1 wheels/6 piston Brembo's/GForce DS and axles/ZLE Cradle Bushings/FE4 ARB front & rear/SEMA Grill/Rotofab dry/95mm TB/Magnuson Heartbeat with 85mm pulley/Full LT4 fuel system/JMS boost-a-pump/Skidmark Garage E85 Sensor/JRE Smooth Idle Cam/GPI piston/rod kit /APR main, head, balancer bolts/Kooks 1 7/8 headers with high flow cats/JRE remote tuned |
#10 |
Wise choice.
2016 NGM 1SS A8
Thread Tools | |
