03-11-2018, 08:51 PM | #1 |
Drives: 17 SS a8 Join Date: Feb 2010
Brake issue, sinking pedal after bleeding brakes
I put on the 15”(wheel) rear brake kit and bled the brakes. Now I have a slowly sinking brake pedal when I step on the brakes. It’s not spongy, it is sinking. I went ahead and bled them some more, about 10 cycles per corner and the problem is still there. I never let the fluid get low and there are no leaks.
Any ideas? Seems like a bad master cylinder. Maybe there is a special brake bleeding procedure we need to use?
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
03-12-2018, 05:13 AM | #2 |
Had my calipers powder coated Friday and I’ve tried all weekend trying to bleed my brakes but it’s still sinking and soft. I give up and calling dealer this morning.
03-12-2018, 01:24 PM | #3 |
Drives: 2017 Nightfall Grey Auto 2SS Join Date: Mar 2012
I have the same issue, but its only when I'm just sitting.
Driving it you can't tell anything is different. |
03-12-2018, 01:47 PM | #4 |
I guess I should go drive it.
03-12-2018, 01:52 PM | #5 |
I drove around quite a bit Sunday and its not sinking as bad but definitely not as hard as should be. Got an appointment with dealer tomorrow morning. They "owe" me a service so I hoping I can get this done almost free.
03-13-2018, 11:25 AM | #6 |
Just got back from dealer and back to normal. They just did thier “normal” brake fluid flush procedure. Sorry I didn’t get any more info than that.
03-13-2018, 03:15 PM | #7 |
You can only YOLO once.
Drives: '16 2SS & '15 Subaru Forester Join Date: Jan 2016
Yeah sometimes you can get a bubble in there even if you try really hard not to.
2016 Camaro 2ss
-Summit White / Ceramic White -8A, NPP, MRC, Ceramic White package plus knee pads, black bowties. -1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns. -1st Car to have the 6LEDesigns Blade Spoiler. -Borla S-Type w/ custom H-Pipe -Procharger P-1X Stage 2 |
03-13-2018, 05:04 PM | #8 |
I tired the mallet on the caliper trick. Didn’t help at all. Sounds like I need to go through the “automated bleed cycle”. It will be in for an alignment soon, maybe I will just have them do it.
03-14-2018, 08:21 AM | #9 |
I did get to drive my car last night and didn’t notice the issue. Strange.
03-14-2018, 08:01 PM | #10 |
If it comes back, old trick I uses to do years ago. Get a oil pump can, install hose to bleeder, pump fluid caliper up. Used this trick with Harleys and DOT4.
2016 Camaro 1SS, Red Hot, K&N Blackhawk intake, Whipple Supercharger, 3.125 pulley, Kooks 2" long tube headers, High flow cats, secondary cats delete, Mishimoto catch can, P3gauge, Lots of dress-up crap that don't make it go any faster.
Car Journal http://www.camaro6.com/forums/showthread.php?t=490975 SC build http://www.camaro6.com/forums/showthread.php?t=492656 Drive, Ride, Fly It Like You Stole It GO BIG OR GO HOME |
03-15-2018, 08:33 AM | #11 |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
Something basic that may help http://www.tceperformanceproducts.com/caliper-mounting/
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
03-15-2018, 09:13 AM | #12 | |
Turns out things are not good enough. After some aggressive driving last night I could smell my brakes and the rear rotors were at least twice as hot as the front. I am going to have to sort this out before I continue tuning. Someone suggested Teflon tape on the bleeder threads and using a mightyvac, I have that stuff and will try that next. If that doesn’t work I may just take it to someone that can do the “automated bleed cycle”.
03-15-2018, 03:09 PM | #13 | |
Drives: 2017 1SS 1LE Join Date: Jun 2016
2017 SS 1LE.
03-16-2018, 12:23 AM | #14 | |
Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
