03-02-2011, 10:24 PM | #1 |
Drives: 2011 Camaro SS 2SS/RS Join Date: Aug 2010
Technical question, Stock throttle body size?
Does anyone know what size the stock Throttle body is on the LS3? I am thinking 90mm But not 100% certain on that, Can anyone shed some firm advice on this?
Thanks All; Scottie
03-03-2011, 08:10 AM | #2 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
The LS2/3 are 90mm.
03-03-2011, 08:33 AM | #3 |
Exactally what I was thinking... I appreciate the info
07-31-2020, 08:43 AM | #4 |
Drives: 2011 Camaro 2SS Convertible Auto Join Date: Jul 2020
is that the same for the L99?
08-23-2020, 02:45 PM | #5 |
Drives: 2010 Chevy Camaro 2SS W/RS package Join Date: Apr 2020
So if I was to get a 92mm would the stock computer compensate for the extra 2mm?
08-23-2020, 02:53 PM | #6 |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
i wouldn't waste the money on 2mm.
what other mods have you done that necessitate a larger throttle body? |
08-23-2020, 08:35 PM | #7 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Stock throttle bodies are capable of 1500+ hp. No reason to change it
08-24-2020, 10:45 AM | #8 |
Drives: 2014 Chevy Camaro SS Join Date: Dec 2014
08-24-2020, 04:21 PM | #9 |
Drives: Silver 2014 Camaro 2SS Join Date: Dec 2018
I’ve debated a larger TB myself. But if stock TBs work perfectly fine for 1500hp, why is there a marker for aftermarket? Does aftermarket really have any added performance over stock?
2014 Silver 2SS L99 with Roto-Fab CAI, Kooks LT Headers, Kooks Cat-less 3” exhaust, TS Stage 3.2 VVT CAM, Circle D 3200 Stall, E85 Kit, FIC 850cc injectors and Elite Engineering Catch Can. Dynoed at 478rwhp.
08-24-2020, 04:44 PM | #10 | |
$ to hp ratio may leave you wanting to spend that money in other places first.
09-15-2022, 10:05 PM | #11 |
693RWHP w/o nitrous
Drives: '12 Camaro SS, Whipple 10.93@128mph Join Date: May 2022
I have a 2013 L99 that I have a 3.0L Whipple I just put on a couple months ago and was thinking about putting a 103mm on. Any educated opinions??
09-16-2022, 05:41 AM | #12 | |
Drives: 2014 1SS/1LE Join Date: Nov 2015
Sent from my Pixel 5 using Tapatalk
830 WHP 700 WTQ, Whipple 2.9 @ 13lbs Boost, Flex Fuel Tune by Blevins Tuning, LSA SBE, 3.5 GripTec, ATI LS3 Damper, AFR 260cc Mongoose, ARP Studs, Yella Terra Ultralites, Johnson 2110R, BTR PDS Stage 3, Melling 10355, Improved Racing Baffle, ID1050X, DSX Triple Fuel Pump, RotoFab CAI, NW 103mm TB, Stainless Works 1-7/8" LTH to 3" Speed Eng w/ X-pipe to NPP, Powermaster 9509 XS, Detroit Speed Motor Mounts, MGW, Monster LT1-S, ZL1 Calipers, DBA Rotors & Pads, Bilstein B6 Struts & Shocks, BMR 1.25" Drop Springs & Adj Rear Bar, Pegasus Solid Bushings, Z/28 Wheels, other misc parts.
09-16-2022, 08:39 AM | #13 |
Hey there Larry, glad that worked so well for you!! Nice gains for just a TB... Kinda wished I would have just kept it and used it on my LOD just to see what it would do for my setup, but glad it worked well for yours.
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
L99 Auto 2nd Gear Question | ChevyMuscle | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 14 | 02-02-2011 07:21 PM |
ADM Performance Ported Throttle Body = 6rwhp + 6rwtq | Number_9 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 31 | 05-25-2010 07:11 PM |
Throttle Body Porting | lxporting | V8 Bolt-Ons & Tunes | 133 | 05-10-2010 12:23 AM |
Ported throttle body sale | matt d. | V8 Bolt-Ons & Tunes | 3 | 11-24-2009 12:11 AM |
