Old 10-13-2017, 06:39 AM   #15
DSX Tuning
Drives: 2019 Corvette ZR1
To be clear, DMS is a reseller of DSX items.
To purchase my things direct, head to www.dsxtuning.com.
The photo on their site is a version they originally made. My system only has two fuel lines, no regulator, and doesn't use a Hobbs switch (I use a CAN controller).
DSX Tuning is offline   Reply With Quote
Old 10-17-2019, 08:59 AM   #16
Choda
Drives: Turbo 6.2
I really like the idea of using the MAP instead of a hobbs switch. this alone puts you above the other kits. My question is can the "on" boost activation be changed from 10psi to something lower like 4 or 5?
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100
Choda is offline   Reply With Quote
Old 10-17-2019, 09:28 AM   #17
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Yes it's been done before. Oldman had his programmed for 4psi I believe.
That being said I have heard others say they prefer hobbs switch over the map controller because of odd fueling on the hit. I don't know any more details...I am sure they both work fine when setup correctly.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 10-17-2019, 01:21 PM   #18
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
I will be doing something this winter on a low side fuel system.
Old 10-17-2019, 02:46 PM   #19
Umbriel
Drives: 2016 Camaro SS
I went with a Crawford Racing port injection system, great quality and Chris is super helpful and very nice. It isn't cheap but now I have 1400 hp worth of fuel if I ever want to go that far, which I will.
Umbriel is offline   Reply With Quote
Old 10-17-2019, 02:46 PM   #20
JANNETTYRACING
JANNETTYRACING's Avatar
Originally Posted by exxit View Post
I'm wondering if just the aux fuel system will cut it without a cam, high side, low side, injectors etc etc
Looking at your build absolutely not, you will need all of the above.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 10-18-2019, 08:41 AM   #21
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
That's the way to do it..
It's funny back in the 5th gen days the Tuners were all saying do not slouch on the fuel system you will blow something up.. its not worth it. Spend the money on the fuel system do not go cheap on this part of the build!
What happen to that preaching? Seems like its more critical on the 6 gen since you can't just tune of off good AFR's. Low side or high side falls of even with good AFRs chances are somethings gonna break..
And what happen to the consensus saying use meth only for cooling do not rely on it for fueling that went out the door to or what?
Old 10-18-2019, 10:24 AM   #22
Choda
Drives: Turbo 6.2
me too, im reading and reading and reading
for $4,849.00Sale Price before buying a new intake manifold... holy moly. This might be over kill for us looking for 800 wheel.
im glad your in here, i enjoy reading your informational posts and the results you post. The more i research, the more I see support for your JMS "NO MATTER WHAT". Meaning we should all look into the jms voltage system if we have stock fuel pump, have stock fp and adding aux kit, upgrading fp, upgrading fp and aux kit. Everyone seems to swear by the jms.
I snipped part of your post, but I agree 100%. I just replaced a lt1 motor for ~12k. goes with the old saying "oil is cheap, motors are expensive". Well yes a sufficient fuel system is not cheap, but still no where near the cost of replacing the engine.
Old 10-18-2019, 11:19 AM   #23
JANNETTYRACING
I have been preaching it for ever and daily I guess no one hears me LOL
Old 10-18-2019, 11:22 AM   #24
JANNETTYRACING
Always glad to help, don't hesitate to call me if you need help.
Ted.
Old 10-18-2019, 11:27 AM   #25
Umbriel
The fuel system and the Procharger intake with port injection bungs was right at $7800 but now I can do whatever I want and never have to worry. I have a forged 416 short block, boost cam from GPI, chromoly driveshaft, GeForce axles going in with the fuel system and will be running a F1-a Procharger on 18+ pounds looking for 1000 rwhp. These cars are not cheap to go fast in.
Old 11-05-2019, 01:04 AM   #26
zepol9
Drives: 2016 Camaro 2SS NGM
please tell me i dont have to remove the passenger rear wheel asembly to drill and tap the dam thing HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
zepol9 is offline   Reply With Quote
Old 11-05-2019, 08:35 PM   #27
Choda
Drives: Turbo 6.2
pic? you shouldnt have to remove the wheel to drill and tap the tank.
Old 11-05-2019, 11:24 PM   #28
zepol9
ok ill post in a bit
