01-03-2017, 04:06 PM | #1 |
Drives: 64 & 07 Corvette Join Date: Aug 2009
★ Get Rid Of Interior Noise in SECONDS- Blockit Sound Deadener Solutions
Quiet down your interior In Seconds!!
As a new forum sponsor, we are excited to release & announce our Blockit "Quick & Quiet" Sound Deadener mat for the Gen 5 & 6 Camaro! What makes our product so unique is that there is no adhesive. You don't rip anything up. The Blockit pre cut mat lays right over your existing factory carpet in the trunk or the stock metal trunk floor. Reduce irritating interior noise in SECONDS by simply placing the precut Blockit Quick & Quiet Sound Deadening mat right over your existing trunks carpet! This is NOT a thin single layer mat! The BLOCKIT is a unique 4 layer combination of real acoustical soundproofing. It measures 1” inch thick! It absorbs and suppresses unpleasant sounds. It quickly helps quiet your interior in seconds. It’s perfect for taking that annoying edge off tire, road noise (especially certain states with certain roads that make tires roar), stock & some aftermarket exhausts. NO need to take apart your trunk, measure, cut and apply permanent product. Just place the Blockit in & go! You can place a rubber mat or aftermarket carpet over the Blockit if you like. You can always take the Blockit out on track events. Install back for the trip home The BLOCKIT also helps keep your cargo area cooler by suppressing heat from underneath too! No adhesive. Removable & reusable. So quick so efficient, we had filed for a patent! All Products are made in the USA. All Raw Materials are from the USA too! Manufactured under strict ISO 9001-2008 standards! Check It All Out Here! http://store.tkoperformance.com/camaro21.html ________________________________________ If your looking to take it to the next level of quiet, check out our DEADMATS! Nothing creates fatigue & ruins a cruise in your ride faster then irritating interior noise! Blockit Dead Mats use a unique technology to eliminate unwanted vibration & noise in your vehicle. It’s not your typical mass loaded vinyl. The thin light weight mats are a highly damped proprietary mineral filled viscoelastic polymer which provides outstanding sound & vibration reduction. At only .445 lbs per sq ft the performance to weight ratio is amazing. The bottom line is the Blockit DeadMats are light weight and are designed to simply not vibrate! The self adhesive backing makes for a simply cut and stick application. Cargo area. C7 Door Under seat • Extremely effective at damping & blocking unwanted noise & Vibrations! • Thin & Light Weight! • Performance to weight ratio is amazing! • Improve your audio’s sound quality! • Textured top layer looks great once installed! • Very durable. Won’t rip, tear or break down overtime! • Helps reduce heat! • Simple peel and stick application! • Apply to any make or model where its needed! • No smell! • Manufactured under strict ISO & automotive regulations! • Made in the USA! Check It All Out Here! http://store.tkoperformance.com/camaro21.html __________________________________________________ ______ Any questions, always feel free to contact us. 800 778 9898 or via email sales@tkoperformance.com Thank you for reading this post. We look forward to hearing from you. Ed |
01-06-2017, 12:11 PM | #2 |
Let's see some before & after SPL measurements, please! This should be pretty straightforward if it actually reduces noise.
01-06-2017, 02:49 PM | #3 |
Drives: 2016 SS Convertible Hyper Blue Join Date: Apr 2016
That would be interesting to know.
Blacked bow ties, full bigwormgraphix blackout
Gm splash guards Mishimoto catch can Black hash marks Curb alert Vitesse controller Jl audio HD 900/5 amp c5 650 components c2 650x coaxials rear fill 2 x 8" W3v3 subwoofers custom ported box Fix 82 module BF TPNS BF Wet Diamond BF Crystal Seal Hydr02 303 Aerospace top protectant |
01-06-2017, 03:36 PM | #4 |
01-06-2017, 04:11 PM | #5 |
Since I did a full stereo upgrade ive already installed hushmat in the doors, rear quarters, and trunk but I wouldn't have an issue adding the pad in the trunk, IF IF it might give me a bit more noise reduction.
