dave@hennessey
Old 08-14-2016, 05:25 PM   #43
old motorhead
Drives: Maggie blown LS3 vette
You should be seeing more than 9 to 11psi with the way you're set up. Might want to fix your belt slip before adding additional mods. Boost shouldn't vary 2 psi either....unless you're comparing boost at 10 degrees F vs 100 degrees F. Even then, it probably shouldn't vary 2 psi. Your belt is slipping.
old motorhead is offline   Reply With Quote
Old 08-22-2016, 04:23 PM   #44
sam.u.el
sam.u.el's Avatar
Drives: 2012 2SS/RS Rally Yellow w/ blk
Originally Posted by JANNETTYRACING View Post
Give me a call I will be happy to put a quote together for you, I carry everything you need including the Flex fuel sensors.
Ted.
After doing more research on the e85 I'm pretty sold. Sounds great over all! I'll be giving you a call sometime within the next week or so to price it all out.
Quick question until then. I have the ID850 injectors and ZL1 fuel pump with your FPCM. With where I'll be power wise, will I need to upgrade the fuel pump and injectors again or will I be ok with what I have as of right now?
Also, will it be necessary to upgrade the fuel rails?
Appreciate your time and advice!
sam.u.el is offline   Reply With Quote
Old 08-22-2016, 07:35 PM   #45
JANNETTYRACING
JANNETTYRACING's Avatar
I believe what you have may support your original goal but will more than likely be right on the edge.
You will not have any wiggle room to take advantage of moving to E-85.
I will speak with you in detail when you call.
Thank you for your business.
Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 09-06-2016, 09:58 PM   #46
sam.u.el
sam.u.el's Avatar
So I decided to pull the trigger and ordered the Fore L1 fuel return system, ID1300 injectors, and flex fuel sensors from Ted. I'm really looking forward to where I'll be after its all said in done. I'll keep this thread updated when I have it all dialed in with new numbers after the E85
Old 09-07-2016, 09:07 AM   #47
JANNETTYRACING
Thank you for your business, any questions during the install don't hesitate to call us.
Looking forward to turning it up.
Ted.
