05-15-2014, 03:02 PM | #15 |
Runs with scissors...
Drives: '14 Z/28s SIM/SW Join Date: Jan 2013
From GM press release:
2. Rear spoiler with ‘wickerbill’ At the outset of development, the aerodynamic coefficient of drag goal was achieved with original Camaro SS content and an accessory rear spoiler, but to meet the downforce requirements for Z/28, the rear spoiler was modified with a “wickerbill” – a small, vertical tab at the edge of the spoiler. Although an aesthetically minor change, it adds approximately 28 counts of drag, improving rear lift performance by 70 counts. That allows the Z/28 to handle turns at higher speeds and delivers greater overall high-speed stability.
05-15-2014, 03:02 PM | #16 |
Q: how much is a count?!?
05-15-2014, 04:28 PM | #17 |
05-18-2014, 08:26 PM | #18 |
Drives: 1968 RS/Custom & 2014 Z28 Join Date: May 2014
anyone found the best place / price to order one of these yet?
05-18-2014, 08:42 PM | #19 |
Order from dealer
05-18-2014, 09:19 PM | #20 |
going to check to see what kind of discount i can get from my Z28 dealer but found these guys online... seems like a good deal... anyone ever order from them?
http://www.hendrickgmparts.com/OEMPa.../23200130.html |
05-18-2014, 09:52 PM | #21 |
Drives: 2010 ZR1 "Satan" Join Date: Nov 2013
I can't see how that's going to be better than putting a wing on it that has an inverted airfoil cross-section. Very little drag, and a lot of negative lift
2002 Z06 "Blue Meanie" 11.36 ET
2003 Z06 in progress 2009 CTS-V "Spooky" 12.36 ET, bone stock at 1600 mi. Rainy day in Sacramento. Sadness. 2010 ZR1 "Satan" no times yet. 2013 Volt SCCA Solo2 #771 HS3. And a bunch of Duramaxes. |
05-18-2014, 10:36 PM | #22 | ||
Drives: G5.R Join Date: Sep 2010
05-18-2014, 10:55 PM | #23 | |
Drives: JST FAST Join Date: Feb 2014
Wings and things...
IIRC, in some racing organizations, which class according to mods; there might be an advantage to staying with the "stock parts". Even if, as you said; the wing will probably provide more downforce, more efficiently. 'Course wid yers, Pat, things could be totally diff; 'cause you ain't gonna have no "aire condishening". You guys are a hoot. Best Regards, John |
05-18-2014, 11:20 PM | #24 | |
Drives: 14 1LE Join Date: Mar 2013
LMS Engineering
05-19-2014, 07:43 AM | #25 |
Drives: BAC Mono Join Date: Apr 2013
The OE wickerbill comes with a template for drilling. Be hard to mess that up. Can't wait to put holes in mine!
2014 Z/28, White
"I wasn't asked to make it cheap...I was asked to make it FAST!" Mark Stielow, the new Z/28. |
05-19-2014, 08:35 AM | #26 |
called Hendricks this morning, as expected still showing in there system as unavailable. i'll just check back at the end of this week to see is the 5/24 date holds true
05-19-2014, 08:55 AM | #27 |
Drives: '06 Pontiac GTO M6, '19 F150 2.7TT Join Date: Nov 2008
I guess the best of both worlds would be to buy another spoiler, paint it black and add the wickerbill and Keep the original spoiler undrilled.
05-19-2014, 11:01 AM | #28 |
Drill it! Nothing wrong with that, it is a factory item. Now if it were not a factory item I would not drill but use tape, but then not adjustable.
