Old 06-18-2018, 08:54 AM   #1
Prochargedgen6
Drives: 2017 procharged camaro 2ss
Jacking up by the rear end
Has anyone out there used the rear end to lift the car? It looks like it would be easier to put the drag radials on and off? Help!!
Prochargedgen6 is offline   Reply With Quote
Old 06-18-2018, 09:01 AM   #2
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
If you mean use the differential housing, the answer is NOOOOOOOOOOOO!
Never with aluminum differentials for lifting. They are nothing like the old cast iron pumpkins in strength.
Old 06-18-2018, 09:34 AM   #3
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
I used the cross member just behind the rear diff. That location worked great. Its a nice flat surface for the jack pad and was sturdy enough to use to lift both rear wheels at the same time.
476 rwhp/440 rwtq (sold)
Old 06-18-2018, 09:38 AM   #4
Laststandard
Drives: 2018 1SS 1LE
Yep, best place to lift the rear end. I throw a scrap piece of 2x2 lumber on top of the jack and lift away.
Don't forget to chock the front wheels if lifting the back end first!
2018 1SS 1LE (sold)
Laststandard is offline   Reply With Quote
Old 06-18-2018, 10:25 AM   #5
Prochargedgen6
Mine is the cast iron housing, it's the only reason I was considering using it as a lift point
Old 06-18-2018, 11:12 AM   #6
Laststandard
Pretty sure the standard SS comes with an aluminum diff housing. Only the E-LSD diff has a cast iron center section, 1LE / ZL1 models.
2018 1SS 1LE (sold)
Old 06-18-2018, 12:45 PM   #7
Prochargedgen6
I'll do the old magnet test when I get back home, the center section in mine is huge, and it sure looks like there only aluminium is on the drive side cover
Old 06-18-2018, 12:46 PM   #8
Prochargedgen6
I'm going to have to do something with it, was pretty happy to I started testing 0-60 and is just a big ol burnout thru 4th gear with the TC off
Old 06-18-2018, 04:01 PM   #9
parbreak
Drives: 2017 50th Camaro SS
Welcome to the world of Procharger!!
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
parbreak is offline   Reply With Quote
Old 06-18-2018, 04:51 PM   #10
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
I'll do the old magnet test when I get back home, the center section in mine is huge, and it sure looks like there only aluminum is on the drive side cover
Even if the differential is iron the independent rear suspension doesn't lift the rear end the same way that the old solid axles did on the previous generations. I don't think the 6th Gen structure is designed to be lifted by the differential alone. I think the cross member or the pinch welds are better lift points for the rear end.
Old 06-18-2018, 06:18 PM   #11
Prochargedgen6
Thanks for everyone's help, and this is why I ask cause I'm not sure how long it would have taken me to notice that cross member behind the differential, but I got it now,
Old 06-19-2018, 08:16 AM   #12
majik755
majik755's Avatar
Drives: 2017 Camaro RS Fiftieth Anniversary
Ditto this, I believe the owner's manual also shows the rear cross member as a lift point as well as the pinch welds.
majik755 is offline   Reply With Quote
Old 06-19-2018, 09:43 AM   #13
TJay74
Been lifting my 1LE using the center diff with no issues for almost 1.5 years now. It holds the weight of the car when it is on the ground sitting.
Old 06-19-2018, 10:45 AM   #14
DC5
Drives: 2019 Chevrolet Camaro SS 1LE
Actually, it does not . . .
DC5 is offline   Reply With Quote
