04-24-2017, 01:37 PM | #15 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Short tires could be fooling the ABS into thinking you were decelerating somewhat more rapidly than was actually the case. More tire revs per mile = faster dropping of tone ring teeth/second on deceleration even before considering the better grip that the Toyos probably have (once warm, at least). If there's an upper threshhold on decel in the ABS programming, you could be tripping it. Perhaps JusticePete knows more.
Norm
'19 WRX 6M (the family sedan . . . seriously) |
04-24-2017, 01:39 PM | #16 |
Drives: 2012 Camaro SS Transformer Join Date: Sep 2013
RF seat chatter maybe???
Mods: trunk subwoofer and amp, LED lighting (fogs, interior, trunk), skip shift eliminator, CAI cold air kit, Vmax ported throttle body, Stainless Works retro chambered cat back, JBA Cat4ward SS ceramic coated headers Potential Next Mods: Tune, F&R sway bars, rear cradle bushing inserts and trailing arms |
04-24-2017, 07:43 PM | #17 |
Apex Predator
Drives: 2010 2SS/RS M6 Rally Yellow Join Date: Jul 2013
Bahaha I needed that!
2010 Camaro 2SS/RS - LS3/TR6060, Paid Off \o/
Beating physics into submission since 1991. |
04-24-2017, 08:31 PM | #18 |
Drives: Camaro Justice Join Date: Jun 2007
This occurs with the wheel straight or turned or both?
04-25-2017, 06:57 AM | #19 |
Apex Predator
Straight primarily...sometimes while trail braking in.
04-25-2017, 07:04 AM | #20 |
Do you ever see ICE Mode?
04-25-2017, 07:07 AM | #21 |
Apex Predator
I hit up one of my "inside sources" at our favorite manufacturer and confirmed the ABS settings are proprietary and owned by Bosch. No way to change/tune the ABS. There is no decel limitation difference between Competitive Mode and Purist Mode. I suggested the settings/firmware might be different between the SS/1LE/ZL1/Z28 and how we might be able to swap them out; he confirmed the Z28 module should work and allow more aggressive decel rates.
Paraphrasing here: [When you change diameter you change the inertia. The ABS is tuned to ensure you don't lock the tire too fast and that you leave enough inertia for it to turn again when it releases. When you change tire grip or diameter you mess with the "tables" stored based on stock values. With CCM brakes, they have 50% more torque output than the stock brakes. They bite so quick the module says holy crap he WILL lock up soon and cuts me off at 0.6gs by activating the isolation valves. The only remedy for this is pumping the brakes to apply more pressure. In all honesty your only way is what race car guys do.... pull module go full no nannies and install a proportioning valve. I know that's not what you wanna hear, me neither but not much left to do aside of deal with the bad abs miscalibration. Other thing is go z/28 module calibration and tire/brakes.]
Beating physics into submission since 1991. Last edited by Lonewolf583; 04-25-2017 at 07:25 AM. Reason: ! |
04-25-2017, 07:23 AM | #22 |
Apex Predator
Based on what others have described I don't think this is ICE mode. The braking distance wasn't overly exaggerated and there was some serious rubber being laid down.
04-25-2017, 08:43 AM | #23 |
Apex Predator
This might actually be ICE mode...
I stand corrected...he seems to think this is ICE mode.
04-25-2017, 08:54 AM | #24 | |
Norm
04-25-2017, 02:43 PM | #25 |
Apex Predator
Ha, happy to spread the knowledge. Now to be clear it'll still look to check if the module expected is what you have...you'll likely have a red ABS light on the dash but in theory it will work.
My buddy at work has an S197 mustang and said the Boss module is a hi-perf unit for him. Not sure how applicable that is for your 195, but still.
04-25-2017, 03:07 PM | #26 |
Mine is an S197 (albeit one of the early pre-Coyote 4.6L cars), and I think the more performance-oriented unit was intended for the Boss 302S (built specifically for World Challenge GTS, NASA® ST2, American Iron, don't think they come with a VIN). I'd expect a warning light; there's a different EPAS unit that supposedly lights the dash up like it was a Christmas tree on the morning of December 25.
Again, thanks. Norm
04-25-2017, 04:56 PM | #27 |
Apex Predator
Lol pardon me, that does sound right
04-26-2017, 08:03 AM | #28 |
Had to track that Boss unit down in the 'whole cars' section of one of the FRPP catalogs. I'd only been vaguely aware of its availability and that it was supposed to work better at truly extreme levels of braking. Which I take to mean R-comps such as what the Z/28 ran and what you'd run in ESP . . . or higher. At 1.0g braking and under (MPSS tires) and my individual braking technique (such as it is) I haven't had any need to chase better ABS behavior so I didn't know what was different other than what I could guess at.
Norm
Tags |
brake, chatter, jpss, toyo, z28 |
