Old 02-24-2020, 10:21 AM   #1
h018871
Geoff
h018871's Avatar
Drives: 2020 ZL1 Green
Oil Fill Funnel??
What are y'all using to put oil back into your LT4? (not sure if the LT1 has the same fill location)
I rigged this up, but it is SLOW! I did find the Motivx funnel, but it will still slope away from the fill hole!?!?
Old 02-24-2020, 10:38 AM   #2
Trochoidal
Drives: 2017 Camaro 2SS A8
It does slope away but you can always get the adapter to make it vertical.
https://www.camaro6.com/forums/showthread.php?t=557645
Old 02-24-2020, 10:50 AM   #3
h018871
Geoff
h018871's Avatar
Thx Trochoidal, is this the one you're talking about?
https://www.motivxtools.com/collecti...ssey-acura-mdx
Old 02-24-2020, 08:35 PM   #4
Trochoidal
Yes that looks similar. Mine came off of one of the tool trucks.
Old 03-01-2020, 11:43 AM   #5
cgdelena
cgdelena's Avatar
Drives: 2019 2SS
this one works well...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
cgdelena is offline   Reply With Quote
Old 03-04-2020, 04:16 AM   #6
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
In a pinch, I've been known to cut the bottom out of an empty quart of oil and have it work quite well. In my LT1's case, I noticed the wife's plant watering can had an interesting shape to it.
I got rid of the bit of plastic with the little holes in it in front and voila! There you have it- the perfect fill funnel for the LT1-
Use your imagination and save a few bucks!
Ventmaster is offline   Reply With Quote
Old 03-05-2020, 11:20 AM   #7
h018871
Geoff
h018871's Avatar
^^That is perfect!!^^
