01-30-2010, 12:32 AM | #1 |
Drives: CGM 2SS Roto-Fab CAI, Mach XL CAT Join Date: Oct 2009
How To Wire Dual Halos On Single Switch
Well I figured out how to wire my dual color halos with a single switch so i dont have to put 2 switches in the dash or use an ugly toggle switch that doesnt lite up when in use. I used the single throw switch that comes with the halo kit. They dont give you a double throw switch they say because they give you that one free but I think it sucks for the money you spend for the lights, How freakin hard is it to get an On-Off-On thats not an ugly toggle Go to Oreilly, Napa, and pick up a 5 pole 12vdc relay and wiring harness. These are very common and easy to get. It needs to have 2 terminals for the coil, 1 terminal for the common and 1 Normally closed contact, 1 Normally open contact. Terminal 85 & 86 are the coil either can be ground or 12vdc- #30 is Common or Ground to the body-#87a is Normally closed (white) #87 is Normally Open (Blue) The only circuit not fused is the coil for the relay everything else is fused through the Halo Circuit I mounted the switch undr neathe the cowl for convenience with a few wire ties First wire the Red positive wire for all the Halos to the existing Halo 12vdc wire. If you dont know take a volt meter and check each wire to a ground bolt if you get 12vdc with the parking lights on then Bingo thats the one. (This is not part of the relay) Install your on/off switch with a 5/8" paddle bit or hole bit in the dash, run your wires through the hole and solder to the switch. I ran the ground from the switch to a bolt in the cabin above the fuse box. (This energizes the light on the switch so you know when its on) Drill small hole through the firewall and run (2) 22 guage wires into the engine compartment. I hid the wires under the engine compartment seal foam along the radiater cover and this is a great place to hide wires it's not glued and comes off real easy. The Middle terminal of the switch I ran over to the the engine fuse box Positive Terminal outside the fuse box (Hot all the Time) This only gives energizes the coil not the lights (control circuit). This also allows you to change the color anytime even without the key in the ignition. The Other wire goes From the Top terminal of the switch to either side of the Coil of the relay and solder. Then Take all four White Halo Ground Wires and Solder them to the normally Closed side of the Relay. (This is so the White halos are the default and operate as normal with the headlights and parking lights. Then take all four of the Blue Halo Ground Wires and wire them to the normally open side of the Relay (Blue will only work when you flip the switch) You then will have 2 Terminals left on the relay, I wired both of these together to wire terminals and mounted them to a body mounting bolt inside the engine compartment (This is Ground) This supplies ground for the color of the Halos Its really quite easy to do and is a simple concept and works like a Charm. This is just a Gratuitis Shot of My Footwell lighting connected to the dome light but I had to put it on here because it looks so freakin sweet Last edited by kismyss; 01-30-2010 at 12:47 AM. Reason: duplicate pix |
01-30-2010, 01:52 AM | #2 |
:chevy:
Drives: 2LT/RS Join Date: Jun 2008
Great write up! Thanks alot, going to show this thread to my installer when i do the fogs (Going to disable the auto headlights and wire the fogs to the switch)
Thabks again, this DIY thread will be very helpful to others
CAMARO
Consult your doctor before taking Camaro Side effects include Sudden increase in Heart Rate, Insomnia and occasional hallucinations If you experience Permagrin exceeding 4 hours after taking Camaro, seek immediate Camaro5 Help CAMARO Bringing excitment back into the Garage |
02-07-2010, 01:58 PM | #3 | |
Drives: 2010 SS/RS Join Date: Jun 2009
Harness part#?
03-02-2010, 02:01 PM | #4 |
Army EOD Vet
Drives: 2010 2SS/RS blk/blk/blk Join Date: Jul 2009
damn wish I saw this thread this morning. I just changed from my rocker switch to a toggle. DAMN DAMN DAMN!
2010 2SS/RS Blk/Blk Camaro F1A Procharger
03-02-2010, 06:26 PM | #5 |
Dog Is My Copilot
Drives: 2011 2SS/RS LS3 Join Date: Jun 2009
Maybe it's the picture playing tricks on my eyes, but do you have dual color halos in the fogs, too?
03-02-2010, 10:53 PM | #6 | |
Drives: 10 LT2/RS-08 SILVERADO-05 COBALT Join Date: Jun 2009
Retired |
03-05-2010, 08:57 PM | #7 |
June '10
Drives: '10 2SS/RS RJT Join Date: Jul 2009
03-13-2010, 04:23 PM | #8 |
Drives: '04 Range Rover, Camaro 2SS 6MT Join Date: Oct 2009
That is a sexy front end, kudos!
CGM 2SS/RS 6SM . No muff.
03-13-2010, 04:57 PM | #9 |
2010 2SS/RS LS3
Drives: '10 2SS/RS LS3 Join Date: Mar 2010
Sweet setup! red would look killer too but i like the blue. gewd job!
03-13-2010, 06:50 PM | #10 |
Drives: Inferno Orange 2010 RS SS Join Date: Nov 2009
03-13-2010, 07:28 PM | #11 |
Drives: Chevy Join Date: Dec 2008
Nice Job on the write up. I love the dual color.
03-14-2010, 12:01 AM | #12 |
does the camaro come with the halos or hid?
03-14-2010, 12:28 AM | #13 |
Dog Is My Copilot
If the Camaro is equipped with the RS package, it comes with both.
03-14-2010, 03:13 AM | #14 | |
SS Lightning
Drives: An SRT8 Join Date: Feb 2008
This is gonna piss cops off !!! Lmao
There gonna Pull you over for blue halos Drivers reaction ... "What Blue Halo's", .. Officer you look tired, there's a Dunkin-Donuts down the road, lol
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
DIY Raptor Dual Stage Shift Light. | ThunderSS | Camaro DIY & HOW-TO instructions & discussions | 47 | 05-27-2019 08:48 AM |
Just got my dual color halo's. | Gnarlygianni | Cosmetics and Lighting Modification Discussions | 2 | 12-14-2009 08:18 PM |
DIY: Here it is Dashboard ambient lighting ABL | Tecca | Camaro DIY & HOW-TO instructions & discussions | 356 | 09-03-2009 10:46 AM |
