11-15-2017, 06:57 PM | #1 |
Drives: 2018 Summit White 1SS 1LE Join Date: Sep 2016
"Winterizing" oil change
So I've had my 1LE for about 6 weeks. Got the oil changed getting ready for the winter nap (have all the stuff ready to go after reading multiple threads). However, the weather is going to be sunny and 45-55 degrees in the afternoon for the next week and I want to drive the car . Should I worry about putting 100-200 miles on the car and not changing the oil again before letting the car sit for 3-4 months?
11-15-2017, 07:17 PM | #2 |
Drives: 2017 2SS Join Date: Mar 2012
You'll be fine
1996 Corvette - LT4
2017 Camaro 2SS 2019 GMC Sierra 2500 HD 2015 Harley Davidson Ultra Limited |
11-15-2017, 07:27 PM | #3 |
376 cubic inches of fun
No. Don't worry.
11-15-2017, 09:03 PM | #4 |
Drives: Hyper Blue 2SS Join Date: Jun 2013
yes. don't worry
2SS, Hyper Blue, 8-Speed Automatic, NPP Exhaust, Magnetic Ride Control, Sunroof, Navigation, 5-Spoke Low-Gloss Black Wheels, Black Bowtie Emblems, Cargo Mat/Net
Mods: XPEL - Hood, Bumper, Headlights, & Side Mirrors JWM - Side Markers ZL1 Addons - Deluxe Rock Guards & Red Lift Pads GM - Dark Tail Lamps MRR - Gloss Black M017s |
11-15-2017, 09:07 PM | #5 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Yes, time for panic!!!
Anyway, just get the car nice and hot to burn off any water in the oil.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
11-16-2017, 08:19 AM | #6 |
Drives: 2017 Camaro 1LE Join Date: May 2017
factory oil is fine for ss 1le. They test these cars in freezing temperatures in product development and research.
11-16-2017, 08:24 AM | #7 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
Ummm.... It's a Chevrolet, not a Formula 1 car. What's the actual concern?
FYI factory fill on the LT1 is 0W-20, according to my UOA.
11-16-2017, 08:30 AM | #8 | |
I used to be Dragoneye...
I think the concern is...the idea of an oil change before winter storage is to put fresh oil in the engine that doesn't have the fuel, moisture, particles, etc in it that could increase chances of corrosion if left in there for a long period of time...so if he changes the oil, will a 100-200 miles of driving until the car is actually put away damage anything. I don't think there will be a problem. Like someone else said, just make sure the oil gets up to temperature to evaporate the moisture. |
11-16-2017, 08:40 AM | #9 |
Hot Dog
Yes, 0W-20. This can't be a surprise. 0W-20's are within the span of Dexos 1 gen 2, and 0W-20 provides the best FE among the approved weights.
If the OP wants to change the oil before and after storage, it's not going to make a lick of difference. The fact is when the car sits for a really long time the oil ends up in the sump, not coating the parts. The engine doesn't know how new the oil is, it only sees that the pump hasn't turned over in months so nothing has been oiled. The best way to stop that is to actually drive the car. Letting cars sit and rot is the worst thing you can do to protect it. Also, driving the car on the street will never burn off the accumulated water, as the cars have a coolant/oil heat exchanger and the oil temps don't get hot enough to boil off the water. This is why driving the cars hard on a racetrack is actually good for the oil, to a point, and doing UOA's prove that. Oil is not a black art, it's science. *edit* I remember a while back you linked to that 540rat guy. He had good intentions but his unwillingness to share his setup and claiming he invented some kind of secret new test that nobody ever thought of is shady at best. His test appears to be a home-made derivation of existing API tests.
11-16-2017, 09:02 AM | #10 | ||
Let it sit...start it in the spring again. One cold start will do less damage/wear than 20...and the oil will stay uncontaminated. Three or four months isn't enough time for synthetic oil coatings to completely drool away from surfaces, especially not in the cold when viscosity increases dramatically. So nothing will "rot". Get the oil to 220 with some regular acceleration, and it'll boil off. |
11-16-2017, 09:13 AM | #11 |
11-16-2017, 09:18 AM | #12 | |
Hot Dog
You're also free to disagree, it's your car and yours to use or misuse as you see fit.
11-16-2017, 09:33 AM | #13 | |
Anyways, Where does it say 0W-20 in that document? Did I misunderstand, I thought you said they told you the factory fill was 0W-20? Dexos certifications concern the quality of the oil anywhere from degradation (for long service life) to catalyst protection. Dexos is not oil weight specific...which is why there are so many different ones that qualify. But just because both a 0W-20 and a 5W-30 both have a Dexos cert. does NOT mean that they can be interchanged. |
11-16-2017, 09:45 AM | #14 |
Hot Dog
An 8.35 cST at 100°C is 20 weight. Dexos 1 Gen 2 is either 0W-20 or 5W-30, so that means my factory fill was 0W-20. Viscosity breakdown is essentially irrelevant for current full-syn oils within a rational service span.
Have you found any other LT1 factory fill UOA's to prove me otherwise?
