Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Forced Induction - V6
Old 06-10-2015, 09:51 AM   #1
gpskinzhut
gpskinzhut's Avatar
Drives: 2017 ZL1 A10
Ramping up to IPF install
Heya guys
I picked up a used IPF kit and I'm getting ready to go through and get things going.
I've got some new pulleys/bearings coming, gatorback belt (107.38 suffice or should I go a size smaller?) and still have to order a catch can. Based on reading some of the feedback and responses in the PCV thread I'm thinking I'm gonna go with the Mighty Mouse setup that Sycraft was using (plus it looks kinda cool).
I'd like to replace the cap screws just for the hell of it as well but i might skip that for now.
Anything else I should be aware of before tearing into things?
2017 ZL1 A10
2017 2SS M6: (SOLD) || 2014 2LT Convertible: (SOLD) || 2010 2LT M6 Supercharged:(SOLD) || 1987 IROC-Z 5.0 M5: (SOLD)
gpskinzhut is offline   Reply With Quote
Old 06-10-2015, 10:37 AM   #2
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
If the kit is used, replace the cap screws. The one for the top idler pulley is easily damaged due to the location for install. Mine got stripped out and I had to spend a day cutting the idler and other parts.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 06-10-2015, 10:53 AM   #3
gpskinzhut
gpskinzhut's Avatar
Ahhh yes, let's definitely avoid that... I'll put a fastenal order together.
2017 ZL1 A10
Old 06-10-2015, 12:58 PM   #4
djrasras
djrasras's Avatar
Drives: 2010 2LT Bumblebee
Originally Posted by gpskinzhut View Post
Heya guys
Im running the Mighty Mouse can as well with my IPF setup based off of Sycraft's recommendation as well, and it is definitely a lot better than the IPF one. Just make sure to get the catch can meant for boosted applications with the one-way valve.
AirLift Air Suspension, Stainless Works Long Tube Headers + Hi-Flo Cats, Resonated X-Pipe, MRT V2 Mufflers, VMAX Ice-olator and Ported Throttle Body, Barton Short Throw Shifter, CAI Intake + Air Scoop
djrasras is offline   Reply With Quote
Old 06-13-2015, 01:52 AM   #5
Slick48
Slick48's Avatar
Drives: 2013 Black RS
Let me know if you need the Install instructions. I have the PDF for the LLT install from IPF. Easy Install if your doing it yourself.
Slick48 is offline   Reply With Quote
Old 06-13-2015, 10:13 AM   #6
gpskinzhut
gpskinzhut's Avatar
Thanks but got them from Andy at IPF. Poor guy has had to deal with a slew of my stupid questions hahaha. Going to plan to tear it apart in a couple weeks. life is getting in the way a bit at the moment.
2017 ZL1 A10
Old 06-13-2015, 10:16 AM   #7
MagnumForceGB
If you have any questions you can also ask them here:
http://www.camaro5.com/forums/showthread.php?t=366755
Old 06-19-2015, 06:33 PM   #8
gpskinzhut
gpskinzhut's Avatar
MM can and breather ordered, fasteners ordered, now just need the tune and it's go time to tear it down!
What plugs are people using?
2017 ZL1 A10
Old 06-19-2015, 08:10 PM   #9
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
NGK or Bosch. Platinum iridium. Ac Delco also has solid pi plugs too.
Lil' Nasty is offline   Reply With Quote
Old 06-24-2015, 10:25 AM   #10
gpskinzhut
gpskinzhut's Avatar
Ty sir, I knew I'd seen a thread somewhere but it wasn't coming up. Found the NGK's on the approved list and have em on the way. Only thing left is the tune from IPF which I'll pick up next week.
My schedule is crap the next couple weekends so looking at the 11-13th to do the install. Once all the parts get here it's going to be hard to wait that long.
2017 ZL1 A10
Old 06-24-2015, 01:45 PM   #11
djrasras
djrasras's Avatar
I still have my stock spark plugs with my IPF setup. What are the benefits of upgrading to the NGKs? Do you just get 1 step colder ones to avoid early detonation?
Old 06-24-2015, 03:39 PM   #12
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
I would look into seeing if they need to be re-gap'd. It says on the instructions and box to NOT re-gap them as they are on factory specs. I would like to know what is a safe spec to gap them to.
I would bet so. I installed these awhile ago so its hard for me to remember.
Old 06-24-2015, 10:00 PM   #13
gutterball
gutterball's Avatar
Drives: 2014 1LS M6 Supercharged
Send a message via AIM to gutterball
I have mine gap'd at 038, Car is running great. use either NGK LTR7IX-11 or AutoLite XP Iridium (XP5263)
gutterball is offline   Reply With Quote
Old 08-04-2015, 11:18 AM   #14
gpskinzhut
gpskinzhut's Avatar
Ordered AEM 30-4406 Boost gauge, AEM 30-4110 A/F Gauge, and a Baron Concepts dual pod. Now just need to order the tune. Getting antsy. Have to swap out the brakes first though. That last ride on the Tail of the Dragon has them squealing pretty good. Dammit.
2017 ZL1 A10
