02-17-2011, 10:11 AM | #43 | |
Drives: 2010 Camaro 2SS/RS Join Date: Sep 2009
Nitrous is an oxidizer that combined with fuel is a power adder. It cools the intake charge because it is cold when it comes out. You can make a lot of hp with it. I have a buddy who squeezes a 500 shot all the time and can go higher than that. Methanol is a fuel that supplements more power. It is usually combined with water and together their rate of evaporation and latency help cool the intake charge. Also, methanol is like 120 octane. With the higher octane and cooler intake charge temperature you can add more timing and/or boost to make more power. Typically you can see up to 50 hp on a forced induction setup.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock 2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo |
04-06-2011, 09:21 PM | #44 | |
Drives: 2010 Camaro SS (LS3, 150-Shot N2O) Join Date: Jan 2011
So I did go ahead and order the nitrous kit. I ordered a NX wet/plate system and the upgrade package.. I'm jetted for 150-shot and tuned with 5.5degrees of timing pulled and AFRs set. I have to say nitrous is the best bang for the buck. My entire kit with upgrades and wideband O2 only cost around $1,500... which beats the hell out of any turbo or supercharger kit. The car takes the 150-shot great. (Though I think it would be better if I removed the converters out of my exhaust) For the person that ask about where everyone is mounting switches.. I mounted both arming switches (master arm and bottle warmer) as well as the purge button along the side of the center console. (Yes this did require drilling).. works great for me.. I launch 1st gear then right after I grab second gear i reach down and flip the master arm back on.. car has a few traction issues with the nitrous.. hopefully this set of NT05Rs I just ordered will fix this. |
04-09-2011, 04:44 PM | #45 |
Drives: Really Slow Join Date: Apr 2010
is the bottle warmer necessary for a place like Las Vegas? Should it be on whenever I want to spray, or just when I want to spray in the winter time?
04-15-2011, 11:30 PM | #46 | |
On a full bottle probably not.. but as the bottle starts to get down to a half or lower it comes in useful. N2O is best at about 1,150psi. A full bottle at 90ish degrees for me is getting 950psi. Once the sun goes down and I'm in about the third round of an EFI shootout with only a half bottle left I can't get over 600psi without a bottle warmer.. (600psi isn't even enough to frost the air when I purge.. and would only give me like a 40hp - 60hp jump instead of the 150 I'm jetted for) As far as when you have it on.. I have mine on whenever my bottle is open. I have the NX automatic heater. It keeps mine at 1,150psi. (just don't ever turn it on with the bottle closed) On a side note. My Nitto NT05Rs did help with my traction issue.. I'm now launching on the bottle.. I cut a 1.83 60ft and went 9.76 in the 1,000ft. Tried to launch from a higher RPM to get my 60ft into the 1.7x range.. but unfortunatly my passenger side halfshaft disagreed with me... it got replaced this afternoon. |
04-15-2011, 11:40 PM | #47 |
Owning SSes for 50 Years
Not For Me!
If you search YouTube, you'll find way too many videos showing disastrous explosions on cars using Nitrous! These happen to people who know what they're doing...imagine what would happen if I tried it....LOL, no, that would not be funny!!!
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars: 1966 Chevelle SS 4M, 2010 Corvette 6M 1968 Dodge Charger R/T Auto 2012 1SS 6M 1982 Corvette Auto 2010 1SS 6A 1984 Corvette Auto 2016 2SS 8A 1999 Camaro Auto 2017 HBM 1SS 1le 2002 C5 Corvette 6M 2018 2SS 2006 Corvette Auto 2023 Camaro LT1 |
04-16-2011, 01:19 AM | #48 |
Only time I have ever seen them blow up was from back fire or leak. Sometimes even the people that know what they are doing try to push it a little to far with the timing.. Also leaking solenoids can flood the intake manifold with n2o and when you go to start the motor.. boom.
I know alot of people that have been spraying motors for years.. one of them has an LS2 on a 350 shot. He has never had a nitrous backfire. |
06-22-2011, 04:12 AM | #49 |
NorCalCamaros.com
Just got a zex kit for my SS, we will see what happens.. I'm holding off on the install until I grab a cam, clutch, injectors, fuel pump, ported oil pump and axles.
Jason |
09-12-2011, 01:33 PM | #50 |
Drives: 2014 1LE 'Summit White' Join Date: Jul 2009
Need Help!
I'm thinking of putting a Nitrous Plate System on my 2010 SS. (150 shots)
My question is Can I use NItrous Outlet Progressive Controller (part# 202-00-6101) to correct the timing and the airfuel? or do I have to get a Time Delay Box ? |
09-12-2011, 04:35 PM | #51 |
I have the NO Progressive and it does not adjust timing or fuel. To adjust the fuel you change jets. And to adjust timing you can reflash the PCM, use the IAT resister mod, EFIL COS or the LNC-002(or similar timing box).
The progressive does have a built in electronic TPS, window switch, progressive nitrous ramp and gear lockout though which are very helpful if you have traction problems.
09-12-2011, 10:13 PM | #52 | |
Would a 'nitrous outlet mini digi-set time delay' work? is there a device that will pull my timing before a run, and put my timing back to stock Last edited by jlugo; 09-13-2011 at 12:05 AM. |
09-13-2011, 08:15 PM | #53 |
Drives: camaro ss 2s Join Date: Sep 2011
As for the nitrous backfire a friend of mine ran a 150 shot in his mustang older stock 5.0 every day all the time his bottle was filled no problems at all when his car passed 200000 mile mark he had his nos on just for kicks that car never had a problem sold the car running great pure stock 5.0 his was a wet kit he did tell me only go with a wet kit they are the best and safest? I plan to put a 150 shot on my 2010 camaro 2s pure stock a 150 wet kit should be fine without any worries.
09-13-2011, 11:16 PM | #54 | |
If you don't want to reflash the PCM then you will need a timing box like the one I posted. You could use the IAT trick but you would still need to set it up in your tune.
09-19-2011, 08:23 PM | #55 |
I want to kill my last write up two messages ago the old mustang did have forged pistons after researching my camaro ss i see the pistons are pretty crappy for nos I would not do it with cast pistons just a fruit for thought after reading they are cast i immediatly thought damn i hope my writeup did not make somebody go try this I have learned that the stock pistons in the camaros L99/Ls3 engines have problems with cracking the powdered rods should be ok if you are running stock pistons cause the pistons will break first but I will say I just would not try it I work with castings and forgings and know how they are and will only say forgings are great casting have a high percent that dont pass pmi for internal cracks. I would like to hear from anyone useing nos on the stock motor and how much you are getting away with for now? I have been searching for a dropin piston kit for these motors with no luck yet. my goal is to change the rods and pistons and run a 175 shot with a tune pretty simple the stock crank is fine now is not so hard on cranks they are much stronger than rods and pistons.
09-24-2011, 07:44 PM | #56 |
navyblueburnout
WOW, Great info everyone. I started reading and by the time I finished ALL my questions about running nitrous have been answered.
Proud member of the Never going back to Moderncamaro.com club!
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Railyard dist. center info; Please read! | HuJass | Camaro Price | Ordering | Tracking | Dealers Discussions | 284 | 04-08-2017 06:41 PM |
Introducing the Nitrous Outlet 2010 Camaro Nitrous System! | Nitro Dave | Forced Induction | 33 | 04-17-2010 08:01 PM |
V6 Camaro Owners! 2010 V6 Zex Nitrous System now available! | Kris@BMCPerformance | Forced Induction | 3 | 01-23-2010 02:41 PM |
New Zex 2010 Camaro V6 Nitrous Kit - intro and free shipping @ PFYC.com | Redshift | Forced Induction | 0 | 07-16-2009 08:31 AM |
Over-the-road Hauling Company info | HuJass | Camaro Price | Ordering | Tracking | Dealers Discussions | 27 | 05-04-2009 12:48 PM |
