Old 08-26-2018, 11:46 AM   #15
ULTRAZLS1
ULTRAZLS1's Avatar
Originally Posted by DFW1LE View Post
I believe stock SS fronts are 27.7", so definitely would be an issue running 26" DRs. What are you running on the front and do you know how much weight the drag pack took off?
17x4.5 race stars. And a 26x4.5 bias front.
Depending on tire choice when I added it up for my setup it was around 80 lbs IIRC
If one went with a more expensive billet wheel weight loss would be about 100 I’d guess as billet wheels are usually at least 5 lbs lighter per rim depending on size
Old 08-26-2018, 03:10 PM   #16
KonigWolf
Drives: 2016 2SS A8
I'm using a 17x9.5 with 38mm offset || 6.75 backspacing with a Mickey SS 305/45
28X12.50. I have slight scuff/light rub marks on the driver side liner. I've put about 800 miles on the tries driving to the track/mehico, an done several burn outs, so I assume to clearances are pretty good.
I have put a 295/35R18, which is a 26" tire out back, keeping the stock tires up front, an the traction control and ABS systems start trying to correct things and I had to pull fuzes to make the car drivable.
16 Summit White 2SS-MRC-NPP-A8 :: PrayPorted IM - LT5 TB - Mishimoto Catch Can - RotorFab - E85 - TSP 2" LongTubes - Speed Engineering X/Mid Pipe
DIY Hpt Tune - DR - 1.75-60' - 7.47@95 - 11.56@120 with +2676DA
KonigWolf is offline   Reply With Quote
