Old 04-13-2010, 08:21 PM   #1
Dforce0990
Deployed Again.
Dforce0990's Avatar
Drives: 2010 2ss/rs iom
Send a message via AIM to Dforce0990 Send a message via Yahoo to Dforce0990 Send a message via Skype™ to Dforce0990
vinyl rally stripe installation question...
Looking for anyone who has personally installed vinyl rally stripes. Recieved my glossy black vinyls today. Read instructions and installation threads on c5. but i'd like some pointers from someone who has done it themselves, and not a shop.
Thanks!
~Tank
'10 Camaro 2SS/RS IOM/IOM Int. #191,037 Welcome Home "Kayla"!
"...But there is another kind of evil that we must fear the most, and that is the indifference of good men."
Dforce0990 is offline   Reply With Quote
Old 04-13-2010, 08:30 PM   #2
1badtie
1badtie's Avatar
Drives: 2018 Camaro ZL1
i used to install a little vinyl jus take yur time do it inside a closed area make sure you clean the entire car before you start and make sure you have a blow torch handy to stretch the vinyl if needed and have lots of tape handy!
1badtie is offline   Reply With Quote
Old 04-13-2010, 08:30 PM   #3
1badtie
1badtie's Avatar
painters tape that is
Old 04-13-2010, 08:32 PM   #4
Dforce0990
Deployed Again.
Dforce0990's Avatar
in the instructions it said specifically not to use a heat source. doesn't say why though. too bad i live on fort hood housing, and the only garage i have... is a carport. have to find a spot of post.
Old 04-13-2010, 08:34 PM   #5
1badtie
1badtie's Avatar
yah i heat is in case you mess up and wrinkle it the heat will stretch it and save it but if you dont mess up which is pretty rare if your not experianced you wont need it no worries jus read the instructions really good
Old 04-13-2010, 09:17 PM   #6
rjcamaro
312 HP
rjcamaro's Avatar
Drives: 2LT/RS RJT
I just did it last weekend. Didn't come out as good as I hoped so I'm doing it over again. It can be harder than it looks.
rjcamaro is offline   Reply With Quote
Old 04-13-2010, 09:27 PM   #7
Dforce0990
Deployed Again.
Dforce0990's Avatar
awesome. will look for a heat source.
Old 04-13-2010, 09:38 PM   #8
az5thgen
az5thgen's Avatar
Drives: 2010 1LT
Just measure carefully - use A LOT of soapy solution, and take it easy!! My wife and I did ours in about an hour and a half and they came out perfect! Just took it in and had the vinyls removed and had them painted on, and the painter used our placement to make his marks, said he hadn't seen a pro do them that good. Take your time, be patient and don't panic. It is a great felling when you see it done! Good luck - you can do it!
az5thgen is offline   Reply With Quote
Old 04-13-2010, 09:46 PM   #9
tmac1granger33
NM HT5
Drives: COTW 3/5/12
me and my uncle installed mine saturday, we measured off more or less put some soapy shampoo water and squeeged em on! got a crease in one.. but the measurements were pretty good... not very hard take your time! its simple enough...
tmac1granger33 is offline   Reply With Quote
Old 04-13-2010, 09:48 PM   #10
GB EB
GB EB's Avatar
Drives: 2014 Stingray 2LT/Z51
what was the price of your painted on? including clearcoat?
GB EB is offline   Reply With Quote
Rally Stripe Issues and Warranty Issues MRKNJ Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 10 06-28-2010 11:59 AM
Red Rally Stripe on Black 2SS? Aftermarket? Rhetor Cosmetics and Lighting Modification Discussions 12 12-29-2009 09:50 PM
FYI - Rally Stripes Will Be Factory Installed talwell Camaro Price | Ordering | Tracking | Dealers Discussions 13 08-28-2009 09:35 AM
Rally Stripe Question cbrniner Cosmetics and Lighting Modification Discussions 7 04-14-2009 01:05 PM
Stripe Opinion and RS Package Question AirBoyzT Cosmetics and Lighting Modification Discussions 27 01-23-2009 01:48 AM
