01-31-2021, 10:52 PM | #169 |
Drives: 6 on the Flo' Super Sport Join Date: Jan 2011
02-01-2021, 05:53 AM | #170 |
Drives: 2021 Camaro LT1 Join Date: Sep 2020
Car does well with all the C7's. But lacks at high speed turns thanks to the 245's. Also runs out of steam at the higher end vs my modded C6. But all in all does fine. Could use another 50hp and lb ft.
02-01-2021, 09:33 PM | #171 | |
Drives: 2016 Camaro 2SS Join Date: Sep 2020
Agree! Granted, if it gets a whole new motor it's still a new motor, however out of courtesy though I'd replace the car. About 20 years ago my mom worked at a Dodge dealer. Someone ordered a Dodge Caravan and they only got a couple miles out of it because the factory didn't put any oil in it!! They got a new van. You'd think they'd notice the oil light though before delivery to the customer at the dealer. |
02-01-2021, 10:17 PM | #172 |
Drives: 18 Ford Raptor, 21 2SS 1LE M6 Join Date: Dec 2020
You should get some 305s on it. I have an SS 1LE with build date of 9/20, but have put 1,500 hard miles on it. The motor was built at the PBC so not sure when the motor was built. Car runs like a beast and keeps asking for more gas. Last check of mpg was 11. Shake and bake
02-02-2021, 05:51 AM | #173 | |
My C6 was around 50 more HP and less weight so i am sure that is why it felt faster up high. I seems to keep up with a C7 down low. |
02-02-2021, 08:12 AM | #174 | |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
02-02-2021, 08:53 AM | #175 | |
Drives: Fast if no one's looking Join Date: Aug 2019
02-02-2021, 08:59 AM | #176 |
Lots of things are possible, but to have a vehicle come off an assembly line with a engine that has no oil in it, make it out to the yard, get loaded on a truck, get unloaded, get driven and serviced by the dealer which includes a road test all with no oil in the oil pan... come on
02-02-2021, 09:06 AM | #177 | |
Hot Camaro
02-02-2021, 09:09 AM | #178 |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
with no oil light?
02-02-2021, 09:22 AM | #179 |
Hot Camaro
Mistakes get made, things get missed. Have you ever had a chance to see a PDI sheet? Sometimes, the tech just draws a line straight down the "Checked" column all at once even though they're supposed to be checked individually and acknowledged one at a time.
02-02-2021, 09:25 AM | #180 |
Fair enough, but someone drove it with a light shining away that they should have seen.
02-02-2021, 09:37 AM | #181 |
Hot Camaro
Very true, but that someone was the new owner who likely had no direct experience in that vehicle and the light wasn't something the realized was an indication of a problem.
02-02-2021, 09:49 AM | #182 |
Thread Tools | |
