Old 03-04-2020, 06:05 PM   #15
A-A-RON
A-A-RON's Avatar
Drives: Chevrolet Camaro ZL1
Originally Posted by Oramac2016 View Post
This is how the connection should look. So far my research is leading to you have to order the whole high mount third brake, or order a whole spoiler. Also hit a dead end on the antenna camera because the response is that its on back order.
Yes, the wrong part showed up. However, the part number doesnt match the diagram my parts guy and I were looking at. I have to go back tomorrow and show him. I think its an error on GM. They shipped me a Backup Camera.
It needs to have a FAKRA Blue cable end. Im working on it though. Here it is in the new Silverado, so its used in more than one application.
A-A-RON is offline   Reply With Quote
Old 03-04-2020, 06:30 PM   #16
Oramac2016
Oramac2016's Avatar
Drives: 2016 Camaro RS
Correct it is used in more then one model. So far it seems you have to buy that whole high mount brake light then strip the camera out of it. Same as the spoiler. Doesn’t seem the camera can be purchased by itself. The 2019 Blazer also have it.
2016 Summit White 1LT RS, Brembo Brakes, NPP Exhaust,Front Glowtie, Rear Red Glowtie, Adrenaline Red Interior
Oramac2016 is offline   Reply With Quote
Old 03-05-2020, 09:29 PM   #17
Oramac2016
Oramac2016's Avatar
Look what I got a hold of
Old 03-05-2020, 09:32 PM   #18
Oramac2016
Oramac2016's Avatar
Old 03-06-2020, 09:08 AM   #19
A-A-RON
A-A-RON's Avatar
What's the part number on that shark antena?
Does it have the BLUE FAKRA connector? I have this part coming. It's a $180 third brake light. Shows in the picture a BLUE connector, so hopefully it's right this time.
I ordered 2x 20' FAKRA extenion cables off of AMAZON and tested them. Worked perfectly.
Old 03-06-2020, 12:33 PM   #20
Oramac2016
Oramac2016's Avatar
That one should definitely work. The cams ive heard confirmed usable are those and of course the ones in the 2019 spoilers. You can get the whole spoiler with camera for about $170-$190 currently. The part# of shark fin cam is 84790625. My journey was to find just the camera at lower cost since i wouldn’t be swapping to ss spoiler due to my rs not having the same hole pattern.
Old 03-06-2020, 09:44 PM   #21
A-A-RON
A-A-RON's Avatar
But does that Sharl Fin have the BLUE FAKRA? I see a CURRY one in your pic. They are color coded for signal transfer.
Old 03-07-2020, 08:59 AM   #22
Oramac2016
Oramac2016's Avatar
Its 3 connections. 2 are same connections as original antenna.(thats the curry wire you see.)Third wire is camera which the connector is black. Installed the fin last night and everything is working. It was a pita to get the antenna out. Mostly because of the room available even with the seat down.
the only connectors that are blue are on the transfer cable like the 20 footer you posted. Which is just like in the trunk picture you posted. Previously I purchased a camera that had a blue plastic band on the connector like i posted on previous pictures but that camera didn’t work at all with the mirror( not sure if the camera was bad or not.)
Old 03-07-2020, 09:10 AM   #23
Oramac2016
Oramac2016's Avatar
Installed
Old 03-07-2020, 09:33 AM   #24
GOMD
GOMD's Avatar
Drives: 2017 Camaro 1SS, 2023 Sierra
Installed
That's awesome, I might just have to try it myself this spring.
Maybe you could eventually write up a short DIY/how to, to help the rest of us out.
GOMD is offline   Reply With Quote
Old 03-08-2020, 08:44 PM   #25
A-A-RON
A-A-RON's Avatar
Installed
Looks good. Ive got my wire ran to the front of the car. Waiting for the camera to show up. Have some fitting and molding to do, but hope to have the front camera done in a week or so. You can seenthe FAKRA cable hanging over the front white crash bar.
Old 03-09-2020, 07:37 PM   #26
Oramac2016
Oramac2016's Avatar
What would be cool is if we could wire up a front and rear cam and have a switch.
Old 03-11-2020, 08:52 PM   #27
A-A-RON
A-A-RON's Avatar
Ive found FAKRA to SMA Connectors, but not any kind of coaxial switch. My camera arrived and it was correct. I've already drilled a hole in the crash bar, installed a grommet, and ran the wire through. Still working on a camera enclosure for the underside of the crash bar trim cover.
Old 03-12-2020, 11:30 PM   #28
Oramac2016
Oramac2016's Avatar
Looking good!! So is the plan to mount somewhere in the front grill?
