03-06-2021, 10:40 PM | #1 |
Drives: 2014 ZL-1 Join Date: Feb 2014
Lunati Signature LS 4.125" Crank and 6.125" Rods...(SOLD!)
I have a lightly used Lunati Signature LS 4.125" Crank. It appears to be a light weight profile. It has 8 slugs of heavy metal in it, and is balanced to 1772g. I also have the set of Lunati Signature I-beam 6.125" Rods (PN 60361250) used with the Crank. The Crank is a 2" pin, and the Rods match with a 2" applicable big end. The small end takes a 0.866" pin. The result is a ~635g heavy duty Rod. The crank was custom finished by Lunati for Warren Johnson. I purchased the package directly from Warren. My plans have changed. My loss is your gain. (SOLD!)
05-13-2021, 05:57 PM | #2 |
PMs answered
05-22-2021, 02:20 PM | #3 |
Drives: 2014 ZL1 Join Date: Oct 2019
Is this still available? Messaged you. TIA
08-21-2021, 12:13 AM | #4 |
PMs answered
09-23-2021, 09:13 PM | #5 |
bump
09-24-2021, 12:06 PM | #6 |
Drives: 2010 Camaro SS Join Date: Apr 2018
hi, do you know the weight of the crank? thanks
09-24-2021, 02:24 PM | #7 |
Without the reluctor wheel, "probably" 47lbs. With it, 47.5lbs. Damn light for a 1,500+HP 4.125" stroke Crank with a $1k balance job (8 sticks a heavy metal).
11-25-2021, 01:48 PM | #8 |
PM answered
01-06-2022, 11:39 PM | #9 |
bump
01-22-2022, 05:21 PM | #10 |
Drives: 13' ZL1, 04 SS Silverado, GS-F Join Date: Feb 2020
Interested in set up. Have the rods been ran as well or just crank? 24x or 58x , will it bolt into a Dart or LSX block? Please send me all info you have regarding the package to mike@greenhorizonsok.com, do you have paper work from work done and receipts from Warren Johnson? Thank you look forward to hearing from you.
