01-30-2021, 10:37 AM | #1 |
Does one piece driveshaft make car quicker ?
For those those that have an aluminum or carbon fiber driveshaft do they make the car quicker from 1st to 2nd without being at WOT? and between the other gears?
01-30-2021, 06:16 PM | #2 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
No
01-30-2021, 06:40 PM | #3 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
Just smoother operation but, with the CF version I saved weight...
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
01-30-2021, 08:14 PM | #4 |
01-30-2021, 08:17 PM | #5 |
01-30-2021, 09:38 PM | #6 |
Drives: 2010 ss camaro Join Date: Dec 2017
I have the aluminum one it doesn’t feel like it’s jerking when going at slower speed like stock driveshaft
01-31-2021, 07:53 AM | #7 |
I have the DSS one and in 1st gear it goes thru it much quicker than the stock one. It allows you to "spin" her up quicker over all if that makes sense to you. And it is much smoother too.
01-31-2021, 10:16 AM | #8 |
Would you say it feels quicker/more nimble going from 1st to 2nd at only half throttle ?
01-31-2021, 02:11 PM | #9 |
Drives: 2010 Camaro SS Join Date: Oct 2013
I would describe the one piece as being more "athletic".
Don't really think it will make the car faster. Most put them on for durability.
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
02-01-2021, 04:08 PM | #10 |
In my car? With the 4200 stall, yes sir. She gets up to speed a lot quicker that it did with the stock unit. Just seems like it, it allows the revs to spool up quicker, kinda like a gear change, it seems to multiply the TQ better, and MY 1st gear is useless!! I start in 2nd now and it still is kinda useless but not as much as 1st is. lol.
02-01-2021, 06:36 PM | #11 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
It will not make you faster. Honestly, I couldn't tell much of a difference between the factory and the aluminum DSS one I had. I haven't put the DSS shaft back in. Just sits in my garage since I had to cut the bolts seized in the diff spacer.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come. |
02-01-2021, 07:12 PM | #12 | |
02-02-2021, 10:19 AM | #13 |
Oh yea, I'm not one to tell stories, I tell you like it is for ME. It was a big difference in my car for sure. Anytime you take weight away from any rotational mass, like light weight wheels and slicks, and DS, you gain the ability to "spool up" quicker and get the car moving easier, in my opinion, in my Camaro. The way I can explain it is with the stock DS when I would throttle up in first she went like,, waaaaaaaaa 7200,shift to second,,waaaaaaaaa 7200, shift to 3rd, now it is waaa 7200,shift to second,,waaa, 7200 shift to 3rd. That 7200 is where my shift point is set at. Anyway, just MY experience with mine.. .. Everybody's experience will be different, because all the cars are not the same. Good luck.
02-02-2021, 10:25 AM | #14 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
I switch to a 3.73 to reduce the car's desire to bog off the line, and that helped quite a bit. It needed all the help it could get so I put an aluminum shaft in and that seems to have helped it even more, but the lower gear definitely did a good bit more than the shaft.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
