01-26-2021, 09:43 AM | #1 |
Drives: 2012 ZL1 m6 Join Date: Dec 2020
heat exchanger options
so i am looking to order my heat exchanger this week. i have been suggested to get the fan option which makes sense. my question is i was told it might be a good idea to go 1" barb fittings over the 3/4" stock.
what hoses need to be changed? will there be any other restrictions that need to be upgraded so the system doesnt flow as much as the smallest hose? i am looking at the weaponX heat exchanger. i have seen the afco for similar pricing with fans. i am open to suggestions. mods below and car will get a cam and e85 next year. kong ported blower 2.55 upper 2" arh headers 5"rpm intake lower thermostat idx 1050s reinforced brick prospeed expansion tank |
01-26-2021, 12:44 PM | #2 |
Drives: 2012 ZL1 Ashen Grey Join Date: Apr 2017
Well I have a afco without fans and a weapon x high flow pump for sale. The heat exchanger is thermal coated as well. All brand new. Being that your not in an area that is extremely hot and humid you prob don’t need fans. That’s what I was told when I was looking. I’ve just decided not to do the mods I wanted so selling everything. Now if your at the track all the time then maybe fans would be a good idea.
2012 M6
Kooks 1 7/8, off road pipes , full corsa exhaust ID1300s/ 22% lower / 2.5 upper, JLT CAI, DSX flex fuel, DSX AUX fuel pump. S19 cam Tuned and built by Speed Inc 635/632-93 octane 725/738-E85 |
01-26-2021, 02:35 PM | #3 |
i am going to build the car to be enjoyed and if my want grow to 1/2 mile, 2/4 mile, auto x, road course i want to just have it done. its only a few hundred more and then i wont have to pull the bumped and spend that money twice.
did you go with 3/4" or 1" or AN lines on the HX? i thought the pump was pretty stout stock? what is the flow on the weaponX compared to the stock pump? MD sees 98 degrees with high humidity in the summer. so i think i am going to go with fans. |
01-26-2021, 04:50 PM | #4 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Ron Davis ftw.
01-27-2021, 10:16 AM | #5 |
i know there are plenty of options. and ron davis, alradco, weaponX, etc.
i am trying to focus on what is needed to convert to 1" hose and not leak coolant everywhere. what all needs to be replaced? 21,19,16,8,7? and all bends and couplers and clamps? do you need to do anything to the pump or intercooler in and out to accommodate 1" hose over 3/4"? |
01-27-2021, 12:49 PM | #6 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
Assuming you did the math calculation that the current pump is going to push any more fluid through a 1/4 diameter increase against the head pressure in the systems. |
01-27-2021, 02:49 PM | #7 |
**did you mean ISNT going to move more**. and that was my thought is upgrading to 1" over 3/4 on a system built for 3/4 without upgrading pump and intercooler is not going to net any results. any idea how much HP the 3/4" hose keeps up with until IATs spike to quickly and take too long to come back down?
01-27-2021, 03:18 PM | #8 | |
Yes I meant the bending of the hoses are the issue with the Head Pressure more so than increasing the diameter of the hose by 1/4 inch vs just getting a faster pump. Here are two good URL'S to read. https://dedicatedmotorsports.wordpre...ump-flow-test/ https://ls1tech.com/forums/forced-in...g-results.html |
01-27-2021, 03:41 PM | #9 |
Another option over a faster pump is running an additional pump in series with the existing one. I have one on each side of my heat exchanger.
01-28-2021, 08:51 AM | #10 |
ok for now i think i am going to just order it with the stock size lines and upgrade the pump when i go more pully and e85. thanks for the data.
01-30-2021, 08:39 PM | #11 |
Drives: '15 Silverado LTZ & '13 ZL1 ragtop Join Date: Nov 2016
The factory pump with an AFCO triple pass w/ fans is my prime setup. I have it backed up for super hot days with a Killer Chiller interchiller which will keep my IAT2s at or under ambient.
HP tune, Kooks 1 7/8" LT w/ cat deletes, FIC 1300 inj, E85, GPI SS3 blower cam, Fore Innovations Gen 5 dual pump module with twin TI Automotive 430 lph E85 compatible pumps, Lingenfelter 10 bolt 2.55" upper/9.17" lower pulleys, AFCO triple pass intercooler with dual fans, Killer Chiller interchiller, B3R insulated expansion tank, full BMR rear drag cradle and suspension, DSS one piece driveshaft and Stage 5 billet axle shafts, Rotofab CAI, reinforced brick, Devil's Own progressive methanol injection, FTI 9.5" billet lock up Street Racer torque converter, 3200 rpm stall, triple clutch.
01-30-2021, 10:10 PM | #12 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
I did dual intercooler pumps and 3 heat exchangers on mine (plus the intercooler brick upgrade and the Roush Cobra reservoir)...
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
Thread Tools | |
