06-17-2020, 08:48 AM | #1 |
Texas speed vvt3 cam and heads
Hey guys! I have a 2018 Camaro ss and I am planning on installing a Texas speed vvt-3 cam (entire kit) and stall torque converter. Would it be necessary to upgrade the heads as well? Or would it just be ideal for more power gains? Thanks in advance!
06-17-2020, 09:47 AM | #2 |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
Might as well have them ported since you have to take them off to do the cam
06-17-2020, 09:49 AM | #3 |
I would. Have TSP port the castings. Good bump in power from head porting.
06-27-2020, 12:14 AM | #4 |
One last question, ( this may seem dumb) But would I need to break in the cam after installation? Or get it tuned right away and then begin the break in period?
Thanks again! |
06-27-2020, 01:21 AM | #5 |
Drives: like an old lady Join Date: Jun 2012
it’s a roller camshaft, all you need to do is heat cycle the springs before you rape on it. i’d get a tune asap after install and limit driving it.
06-27-2020, 10:14 AM | #6 |
Drives: 2018 1SS M6 Join Date: Feb 2018
I would not do more then start the vehichle when you are done to make sure its good.
2018 1SS M6 - OTR intake, HI Ram intake, Ceramic Coated TSP Headers Catless, AWE Touring Axle-Back, Flex Fuel, Pray Performace stage 3 cam, TSP ported heads, Pray Ported 95MM TB and Ported HI-RAM. SJM Line-Lock. F14 Drag Pack 17's with front skinnies. Tuned by Pray Performance.
07-05-2020, 10:49 PM | #7 |
Drives: Chevy Camaro 2017 Join Date: May 2019
Just installed my tsp vvt3 cam on my M6. Drive ability is for the most part the same. Below 1500 rpms it might want Jump back and forth alittle because the cam and then sometimes i can cruise at 1k fine. Only think is on my start up it surges alittle bit, revs up and down for about 20 seconds or so. And then idles fine.
