04-15-2020, 01:36 PM | #1 |
Drives: 2010 Camaro 2SS Join Date: Aug 2016
Pcv line
Is the line going from the valve cover to the air intake tube necessary? The plastic nipple on my rotofab intake snapped off and I found my pcv line just hanging there. Could I just cap the nipple on the valve cover or do I need to get a new CAI?
04-15-2020, 01:51 PM | #2 |
Drives: 2015 Camaro 2SS RS 1LE AGM Join Date: Oct 2013
Cap it and put a breather filter where the oil fill cap is. Its there to vent the crankcase gases.
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
04-15-2020, 03:22 PM | #3 | |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
OP I’d epoxy a new nipple on and reconnect the line unless you want to switch to a breather set-up. Don’t leave it unplugged because your engine will pull in unmetered air which could be bad
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
04-15-2020, 03:31 PM | #4 |
Maybe this is a ghetto idea but could I drill out the intake tube and epoxy the line right into the side of the intake tube? Obviously not far so it’s doesn’t obstruct airflow
04-15-2020, 07:30 PM | #5 |
You NA epoxy it and you'll be fine.
04-15-2020, 08:21 PM | #6 | |
But what the OP is talking about is the clean side which draws in air via the intake tube through the PS valve cover. This is the same on both an L99 and LS3 Read this if you’re curious (halfway through the 2nd paragraph): https://www.camaro5.com/forums/showp...88&postcount=2
2010 2SS/RS
04-15-2020, 08:22 PM | #7 |
Epoxy in a new fitting or see if roto-fab will sell ya a new tube
2010 2SS/RS
04-15-2020, 09:04 PM | #8 | |
