Roto-Fab
Old 04-08-2020, 11:43 AM   #15
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
95% of the people that mod their camaro would benefit from doing the rod mod on a stock manifold from all the videos and stories I’ve read. Other manifolds have there place but depends on the application it seems like and if you also want to modify your hood/wipers.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 04-08-2020, 02:58 PM   #16
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
Personally with the weight of the 5th gen you need all the torque you can get. 3.90 gears is ok 4.10 is a tick better. For the street on a stock height tire and roll racing a lighter clutch is your best option for performance. I would not use anything but a 7.25" triple and youll be amazed at the response when you whack that throttle. I made a 5.5" live for many miles in mine but the 7.25 is the better option. My set up weighs 18 pounds complete utilizing a stock flex plate to start the car.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 04-08-2020, 03:04 PM   #17
Dbunch9
Drives: 2010 Camaro 2SS
Yeah I think I might not worry too much about the intake, stick to the rod mod and worry about the right clutch. I really like the rps bc2 twin
Dbunch9 is offline   Reply With Quote
Old 04-08-2020, 03:51 PM   #18
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
Good call
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 04-08-2020, 05:51 PM   #19
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
I've read so much pro and cons for a light clutch in the cars. Heavy car shouldn't use a light clutch it makes it hard to get moving but its much snappier in. Stalling issues tuning problems with too light a clutch for idle. Makes it a tough choice for me.
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
Greenhornet2 is offline   Reply With Quote
Old 04-08-2020, 06:00 PM   #20
JLGO
JLGO's Avatar
Drives: 2015 Camaro SS convertible L99
The best bang for the buck is the stock intake manifold.
JLGO is offline   Reply With Quote
Old 04-08-2020, 08:03 PM   #21
Dbunch9
Maybe we could shift this post into a light clutch topic? I’m sure lazer has plenty to say. I’m kinda curious what it’s like driving one myself
Old 04-08-2020, 10:25 PM   #22
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
This
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 04-08-2020, 10:26 PM   #23
gunchamp
gunchamp's Avatar
Originally Posted by Greenhornet2 View Post
I think you're over thinking the intake. Are you auto or stick? If auto and you like to race I'd do 2 things if you want to race, 3.91 gears, higher stall converter best bang for your buck for ETs. M6, just the gears. If you've already done those then I'd start worrying about small power increases.
And also this
