Roto-Fab
Old 05-21-2019, 08:01 AM   #15
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
https://store.katechengines.com/416c...lock-p573.aspx
Any one have an opinion on this? They have them in stock...
Its $800 more than the 427....
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 05-21-2019, 08:26 AM   #16
go_go_gadget88
go_go_gadget88's Avatar
Drives: 2010 Camaro 2SS/RS ABM 6M
Since it sounds like your block is fine, I would also vote for the 418 vs the 427. I think it would live a lot longer for you.
I would go the same route as sixty9 and drop in that forged rotating assembly into my block. I would think that you could have your stock parts cleaned up, honed out, and ready to go...and be in it for less than the 5k for that 427 short block. You do have the lack of any kind of warranty that way though, so that IS one appealing part of the shortblock you linked
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
go_go_gadget88 is offline   Reply With Quote
Old 05-21-2019, 10:48 AM   #17
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
Thats because it has a callies rotating assembly
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 05-21-2019, 10:56 AM   #18
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
Katech makes a nice motor, its a little more than everyone else but seems like a good choice, I would run one! You can drive to Katech an pick it up, save on shipping freight.
You can probably get 800-1000 for you lS3 short block that's damaged, someone will buy it and fix it.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 05-22-2019, 07:24 AM   #19
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
Sag performance is who I bought my 428 from, I think for most the 418 is fine and more in line with building for FI, the difference in stroke from 418 to 418 is minute.... the deal is back when they first made stroked ls engines they threw any piston in with out the proper skirts etc etc and on a ls3 you can only over hone .020 max. So many had problem with piston rock and its about a piston actually rocking in the bore form the long stroke.
My pistons are racetec, my crank and rods molnar………… basically none better.....Forged; the pistons the former owner of JE pistons makes because he still wants to work, Molnar makes other names you know and trust....like Callies.. rebranded... Jerry at Custom engine supply ( SAG) talked at me for lengthy conversations and I am very happy with my results and his input to make sure everything is ready to go with the proper engine oil plugs etc and clearance done up good, I used a MAST windage tray and had to alter it also more... I got a complete shipped forged 428 for 5k and then properly had it assembled more and broke it in on the dyno like a engine should be with driven racing br30 for two rounds then vr30 for a few thousand miles. I picked my engine from those that make more than any other because...….. it saved $$$ and I had confidence in them, you would find others if they are good like TSP etc include br30 in the price and yes a new engine does need a twenty to thirty minute break in..... Just some thoughts. Remember to pick the pistons with the compression in mind, my N/A build is 11 to 1 and fine with a big cam with reliefs in it and the rings are good and should be picked for the purpose and the overhone of .005 of the new block...….so its down .005 of the .020 right off the bat and who knows what the bores are like in your cast in sleeves and if they can accept much of a overhone…. that's TBD and a new block yes does cut that out, Custom engine supply is in like Angola Indiana... they shipped to my tuner and yes I scoured the internet and the winter was when it was cheaper to buy...Good Luck.
christianchevell is offline   Reply With Quote
Old 05-23-2019, 07:42 PM   #20
Clarkstar
Clarkstar's Avatar
Picked up the 416 from Katech today. Nice place, even nicer people there. Let the fun begin...
Old 05-23-2019, 09:30 PM   #21
sixty9fordkiller
Sent from my SM-G975U using Tapatalk
Bone Stock
Old 05-23-2019, 10:56 PM   #22
PepeLePew
PepeLePew's Avatar
Drives: 2010 2SS Coupe; 2011 2LT Vert
Now your getting serious!!! Awesome!
2010 2SS/RS LS3 - K&N, GM Performance Axle Back, Hurst Shifter, TSP 1 7/8ths long tubes no cats, TSP Stage 2 "Bald Eagle" cam, GM 3.91, 466whp/429tq
PepeLePew is offline   Reply With Quote
Old 05-26-2019, 04:06 PM   #23
Clarkstar
Clarkstar's Avatar
Getting close...
Old 05-26-2019, 04:15 PM   #24
zz430camaro
Drives: 2015 1LE
Man that is sweet.
Old 05-27-2019, 02:01 PM   #25
Clarkstar
Clarkstar's Avatar
Watch "Katech 416" on YouTube
https://youtu.be/4vhcdUHBa7s
Its alive!!!
Old 05-27-2019, 02:35 PM   #26
zz430camaro
Drives: 2015 1LE
Badass! Man you did that quick, are you going to have it re-tuned because its 40 cubes bigger? ****er sounds good!
Old 05-27-2019, 03:00 PM   #27
Clarkstar
Clarkstar's Avatar
Yes, I'll get retuned. I'm going to break it in and change the oil. Make sure everything is tight... then I'll take it in.
Old 05-27-2019, 03:53 PM   #28
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Give yourself a pat on the back....Impressive,all the way around
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
