TireRack
Old 12-16-2018, 06:22 PM   #1
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Coilover opinions... Pedders or BC???
I'm looking to purchase coilovers. Just a good, affordable street set. Narrowed my search to Pedders or BC. Both are about $1k. One better that the other? Differences?
Thanks in advance!
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 12-16-2018, 07:57 PM   #2
derieu
Engineer
derieu's Avatar
Drives: 2014 Camaro 2SS RS 1LE
Pretty sure both are sourced from the same Taiwan supplier
2014 Red Hot Camaro 2SS RS 1LE
-Sunroof Delete, Recaro, Nav, NPP
-Pegasus Subframe Bushings, JPSS Radius Insert, Detroit Speed Caster Mod, PMAS Intake, Solo High Flow Cats, Ecsta PS91 Tires, MGW Shifter, Pegasus Offset Poly Diff Bushing
derieu is offline   Reply With Quote
Old 12-17-2018, 02:25 AM   #3
rdanzel
Drives: 2010
I know some guys here have the BC's. Hope they will chime in.
rdanzel is offline   Reply With Quote
Old 12-17-2018, 03:04 PM   #4
pump905
pump905's Avatar
Drives: 2011 2ss/rs black with white rally
I am also looking for some found pedders on amazon for $910 shipped just some info for u
pump905 is offline   Reply With Quote
Old 12-17-2018, 06:56 PM   #5
Clarkstar
Clarkstar's Avatar
I seen those, but it says for 2015...
Old 12-17-2018, 09:37 PM   #6
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2021 Shadow Grey Camaro 2SS 1LE
I was told they or at least Pedders made in China, not even Taiwan. Bc brought back engineering or r&d from China do to the usual theft of intellectual property. Both are only good for street use. If that now.
More money but go with Ridetechs
VR Baron is offline   Reply With Quote
