Old 09-21-2018, 11:47 PM   #1
Laststandard
Drives: 2018 1SS 1LE
First track day - a little more positive
Had my first track day today. I'm hooked.
Mods - Track alignment (-2.4 front, -1.6 rear camber), 5w40 dexos 2... everything else stock. Stock pads and brake fluid. Starting tire pressure of 30 psi, 55* here today in MN
Course was at Dakota County Technical College, technical course a little over a mile long. Top speed about 100mph on the back straight.
Holy hell, this car is amazing. I'm a newbie and it makes me feel like a superhero. Started off in PTM Sport 1, switched to sport 2 towards the end of the second session. Could definitely tell the car was keeping me in line while I was hacking away at the steering wheel. Tires are amazing once they get warmed up. Brakes held on for 3 20 minute sessions, even with stock fluid. Had to scrub about 50mph at the end of the back straight, could tell the pedal was getting a bit soft but it never let out on me.
Next track day in a week, can't wait!
2018 1SS 1LE (sold)
Laststandard is offline   Reply With Quote
Old 09-22-2018, 04:36 AM   #2
JD_
JD_'s Avatar
Drives: 2018 2SS 1LE in Nightfall Gray
Very Cool! I see you were using the track addict app. How difficult was it to get set up and how did the video come out?
I have my first two track days 2 weeks from now at VIR and cannot wait.
JD
JD_ is offline   Reply With Quote
Old 09-22-2018, 07:43 AM   #3
slvrsrpnt
slvrsrpnt's Avatar
Drives: 2017 1SS 1LE
very cool and neat looking app!
Our poor tires take a beating, I've done 1 track day and several autocrosses this year. Time for a new set. It's part of the price to pay to have fun!
slvrsrpnt is offline   Reply With Quote
Old 09-22-2018, 09:49 AM   #4
Laststandard
JD
Actually didn't use it for video. Had a cheapy gopro knockoff from Amazon on a headrest mount, video turned out pretty shaky, plus it corrupted the video from my last (and quickest) session... oh well. I have a RAM windshield mount on the way for the phone and I'll be using the track addict app next time.
The app wasn't too tough to set up, that track isn't in the list but setting up a new one is as easy as setting the start/finish line on the map and just driving the course. Couldn't get it to hook up to my OBD2 bluetooth scanner, but I didn't have much time to play around with that.
2018 1SS 1LE (sold)
Old 09-22-2018, 11:16 AM   #5
desertmonkey
Drives: '17 SS 1LE
What exactly does the track alignment help with?
Do you change it back to street alignment after a track day?
desertmonkey is offline   Reply With Quote
Old 09-22-2018, 11:48 AM   #6
Dave-ROR
Drives: A few
Tire wear. And it should help cornering stability/entry/etc also but my car came from the dealer with the track alignment already so I've never driven it without the track alignment.. since then I've just gone more aggressive on the alignment.
Don't change it back from the track alignment IMO. As long as you don't go crazy with toe your wear will be fine.
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback
Too many cars.. never.
Dave-ROR is offline   Reply With Quote
Old 09-22-2018, 12:59 PM   #7
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Tire wear.
Stability in corners.
Improved handling.
Going around a turn all the weight transfer goes to the outside tires. With the camber a little more negative the outside tire stands up rather than rolling over giving you the full tire contact patch to work with instead of just the outside edge.
Front needs more as it's carrying more weight, and doing more work by the actual change in direction.
'18 1SS 1LE Black, PDR
Old 09-22-2018, 06:31 PM   #8
desertmonkey
Drives: '17 SS 1LE
Originally Posted by Boost Creep View Post
Tire wear.
Improved handling.
So regular street driving with track alignment would result in uneven wear?
Do you just leave your in track alignment even when you daily the car?
Old 09-22-2018, 07:04 PM   #9
Alpha1BC
Alpha1BC's Avatar
Not really. Over a really long time, yes the inside shoulders will wear more than the outsides, but with the nearly 0 toe of the track alignment the inside shoulder wear effect is reduced and the outside shoulders will still get evened out at the track. I got my track alignment at 1100 miles and currently sit at 7500 miles and about 6 track days and my tires are showing just a little tiny bit more wear on the inside than on the outside, and all of that was on the track alignment.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 09-22-2018, 08:32 PM   #10
kjchristopher
Drives: 911SC
Toe is what kills tires, and the GM track alignment has almost none.
kjchristopher is offline   Reply With Quote
Old 09-23-2018, 10:44 PM   #11
Laststandard
https://youtu.be/Q_GjLLPXkO4
The video from my cheapy gopro knockoff. Pretty shaky. Hopefully get something better figured out before the next one.
2018 1SS 1LE (sold)
Old 09-24-2018, 04:09 PM   #12
desertmonkey
Drives: '17 SS 1LE
Thanks for the input guys!
I guess I need to get my track alignment done
Old 09-24-2018, 04:18 PM   #13
Boost Creep
Drives: '18 1SS 1LE
I'm sure if you did the track alignment and only drove it on the street you would see inside tread wear by the time the tires are done. People who track the car will even out the tread wear so it will be nearly undetectable.
Old 09-25-2018, 07:36 AM   #14
artey34
artey34's Avatar
Drives: 2018 Camaro 2SS 1LE - Hyper Blue
So if I plan to do a few AutoX and track days a year plus some daily driving, I mine as well just leave it in track alignment the entire time?
artey34 is offline   Reply With Quote
