02-06-2015, 03:36 PM | #1 |
Drives: 2010 2LT RS IBM Join Date: Jan 2015
What is the average life of OEM Battery?
My 2010 2LT RS still has the original battery. The car is under a cover at the moment with about 6 inches of snow atop the cover, It's been below freezing over the last few weeks.
Should I expect to replace the battery once the weather changes? Thanks Tom |
02-06-2015, 03:43 PM | #2 |
Drives: 2011 Black SS M6 Join Date: Oct 2010
5 years is about the average life of a battery. It may or may not need replacement when the weather breaks.
02-06-2015, 04:04 PM | #3 |
376 cubic inches of fun
Since you are not hooked up to a battery tender, your 5 year old battery will be suspect in the Spring.
Under the best of circumstances, 7 years is about the limit. But in your case, it's probably time for a new battery. |
02-06-2015, 04:44 PM | #4 |
Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
I'm still running my oem battery, it's a 2010, more importantly, I've got 99,898 miles and am in an out of my car maybe 20-30 times a day, that's a lot of starting which is the biggest drain on the battery, when it's time to be replaced, most likely going with another oem one.
02-11-2015, 07:19 PM | #5 |
Drives: 2012 SS Black Camaro Join Date: Jan 2015
My brother has a camaro (as well as my mom and dad lol) and he's had his for about 5 years and the battery is still pretty good, so yea it does last a pretty long time.
So far...
Borla Attak Exhaust Volant Cold Air Intake |
02-11-2015, 07:22 PM | #6 |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
When I lived in Florida my OEM's lasted about 3 years max, the heat really played a toll on them. Seems though up north the weather is kinder to them.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
02-11-2015, 07:24 PM | #7 |
Good thread, I've been wondering the same thing!
SLP Loud Mouth 1 Exhaust, K&N CAI, RS Headlights, NightOwl V2 halo kit, ZL1 Grille, Custom 2LS Emblems, Green Footwells, GM GFX splitter, Ace Alloy Convex All Matte Black Wheels(20x9 & 20x10.5) wrapped in Toyo Proxe STII(255/45/20 & 295/40/20)
02-11-2015, 08:14 PM | #8 |
I'll find out in a week or two once the snow on the cover melts. Haven't even had the doors open since December.
The car turns 5 this April and it's been very cold these last couple of weeks (in the teens a lot). Keeping my fingers crossed. Tom |
02-11-2015, 08:27 PM | #9 |
Drives: 2014 Camaro 2SS RS Join Date: Aug 2014
depends on where you live, look at the responses of the people close to you. here in houston 3 years is average.
02-11-2015, 08:41 PM | #10 |
If I wanted to change my battery, what is the best one to purchase? Aftermarket or OEM?
02-11-2015, 09:22 PM | #11 |
OEM is good, I personally like Interstate Batteries.
02-12-2015, 03:00 PM | #12 |
Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
My car will be 6 years old come May, still on the original battery. Sitting is probably the worst for them. Starting and keeping them charged will keep them in better shape. If you leave it sitting for long periods then a trickle charger is the best bet to keep it strong.
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
02-12-2015, 03:40 PM | #13 |
The Camaro battery is in the trunk, so it doesn't get stressed by engine heat. The only OEM battery I had that failed before 7 years was in a cramped minivan engine compartment. It died after less than five years.
02-12-2015, 04:33 PM | #14 |
Don't it figure. A week ago I posted how my oem battery was still going strong, well now a bit over 100,000 miles and after pulling in for gas it wouldn't start. Had to jump it, took it back to the shop and checked the charging system and all is good. It's been starting fine since then so it could be a fluke but I'm putting my money on it being a sign. lol.
