05-11-2014, 10:20 PM | #1 |
Drives: 2014 ZL-1 Join Date: Feb 2014
MT DR2s on a 20x10 or 20x11?...
Disregard
05-12-2014, 05:16 PM | #2 |
ROCK
Drives: 2013 ZL-1 TRIPLE BLACK VERT Join Date: Oct 2012
I have mine mounted on 20X11 Factory Reproduction wheels. Have not been to the track yet...hopefully in the next 10 days. Will post my results.
WHEN ONE AMERICAN IS NOT WORTHY TO BE FOUND...THEN WE AS AMERICANS HAVE LOST. POW/MIA YOU ARE NOT FORGOTTEN
05-15-2014, 12:08 PM | #3 |
Drives: Camaro ZL1 Join Date: May 2012
I run the same tire on the factory reproduction rim for the drag strip. No issues. Dont expect much sidewall bulge. The tires fit almost the same as factory tires.
2012 A6 Coupe 630RWHP 10.93@125
Mods: ID850 Injectors; D3PE HX, Reservoir & Atmospheric Catch-Can; LPE 2.55 Upper & 9.1 Lower Pulleys w/ ATI Damper; LPE Idler Pulley Relocation Bracket; "Green" Serp. Belt; Cat delete;ADM Exhaust Override; Magnaflow X-Pipe Muffler (in addition to stock mufflers); Cold Air Inductions CAI; 160 thermostat; LS9 Isolator; Port/polish snout and intake runners; LPE GT9 camshaft with dual springs and titanium retainers; Kenne Bell BAP, Install and Engine Tune by Serious Hp; Fab work by D3 Performance Engineering; Trans Tune by Keith; Coming Soon: Flex Fuel Conversion. |
05-16-2014, 04:58 PM | #4 |
ROCK
WHAT TIRE PRESSURE ARE YOU RUNNING?
