12-24-2013, 12:03 PM | #1 |
Night Fury push rod length
I ordered a Night fury cam kit. I ordered 7.400" pushrods but received 7.425" rods. are these the correct rod length for this cam. stock ls3
12-24-2013, 12:21 PM | #2 |
10-bolt Destroyer
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M Join Date: Jun 2012
Why are you pulling your heads off just for a cam swap? The heads dont need to come off therefore you dont need to replace your head gaskets.
Some other knowledgeable person here should know more about the timing chain..im not sure on that one.
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq |
12-24-2013, 12:28 PM | #3 |
theses are not head gaskets its a timing cover and water pump kit
http://shop.advanceautoparts.com/buy...tcs-45993.html
12-24-2013, 12:56 PM | #4 |
Drives: 2010 Camaro Join Date: May 2012
Unless you milled your heads. I believe it is 7.425". That is what my is.
12-24-2013, 12:58 PM | #5 |
ok thanks. stock is 7.400 but with this cam 7.425 is correct for the Night fury cam then?
12-24-2013, 01:09 PM | #6 |
You got it...
12-24-2013, 01:11 PM | #7 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Some run 7.400 and some run 7.425 just have to measure and see.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
12-24-2013, 01:34 PM | #8 |
just got a call from Lethal everything is taken care of. There fast. I figured I wouldnt hear anything until after christmas. No got a call 30 min after I sent the email.
12-24-2013, 06:53 PM | #9 |
Drives: LSx Performance Specialist Join Date: Jul 2011
Glad we could get you taken care of. Sorry for any confusion. Glad We could get your order corrected for you.
Shawn |
12-24-2013, 10:36 PM | #10 |
So what's the length for stock heads?
1 7/8" TSP headers straight piped, Custom Tick Performance cam w/ supporting mods, 1" BMR springs and other BMR suspension mods. Tuned with HPtuners by Matt@FSP
12-25-2013, 08:11 AM | #11 |
