11-24-2020, 02:28 PM | #1 |
Drives: 2019 Chevrolet Camaro Join Date: Mar 2020
Why does no one make bolt in high flow primary cats
I know that long tubes are the way to go but what if you are not quite ready for that and still want to stay legal.
11-24-2020, 02:43 PM | #2 |
Do you have to have both cats on to pass inspection? You could do a primary delete which will help some with the flow. GMs done a good job on their Manifolds and Cats. I went 10.00@139 on the stock manifolds and cats with a Maggie 2300.
11-24-2020, 02:52 PM | #3 |
I am 40, don't feel like dealing with inspection bullshit anymore. I thought about primary deletes but just want to make sure I will still pass. I live in Texas so as long as it passes visual inspection and obd2 then it will be fine.
11-24-2020, 03:22 PM | #4 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
If you need them just for visual inspection get some V-Bands. Get your muffler guy to make you two sets. One with your cats and the other just pipe. I use them to disconnect and take off the mufflers at the rear and then just put on a turn down to save weight at the track.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
11-25-2020, 09:26 AM | #5 |
Get some bolt-in primary deletes and move the o2 sensors behind the secondary. Voila... There is your high flow cats. They are very low restriction. The bottle neck in the exhaust is at the connection point between the primary cat and factory header. It necks down under 2" before the flange on the cat pipe.
2016 NFG 1SS A8
11-26-2020, 06:37 PM | #6 | |
I have heard mixed results with that. I have thought about it though. |
11-27-2020, 11:39 AM | #7 |
Drives: 2020 Camaro SS 1LE Join Date: Aug 2020
Are CA Performance pipes still for sale?
11-27-2020, 11:55 AM | #8 |
Drives: 2016 Camaro SS Join Date: Jul 2020
Do you have visual inspection in your parts of TX? In Dallas, I went in with my car smelling like fuel and cam choppin hard, no cats. The dude at inspection was like wow this car seems bit rough lol plugged in the obd2 scan and off i was.
11-28-2020, 07:20 AM | #9 | |
well they are supposed to do visual inspection but most are probably lazy and as long as the obd2 passes they just let it go. |
11-28-2020, 07:54 AM | #10 |
Drives: like an old lady Join Date: Jun 2012
why does no one make bolt in high flow primary cats?
because they would not sell. also, i don't think a bolt in option for anything dealing with the exhaust between the manifold and midpipe exists. fairly sure one side must be cut.
11-28-2020, 07:58 PM | #11 |
Drives: Camaro 1SS A8 Vert Join Date: Sep 2018
I have New Era Cat deletes w/magnaflow high flow cats.
Helped with sound and gas smell. Smells good with E85. |
11-28-2020, 11:07 PM | #12 | |
So theoretically a Shorty/HF Cat combocould get you close to that and keep the stock sound and cost a bit less and be an easier install. But you still will need a tune to keep the CELs away as I heard that restriction was needed to light the first cats quickly. However these would only be annoying CELs, and of course a slightly less effective emission system. Yet Still sort of planet friendly. I wonder if that connecttion could be opened up with a grinder?
