05-08-2024, 06:13 AM | #1 |
Drives: White 2024 1SS M6 Join Date: Nov 2023
ZL1 ADDONS MAGPAD
Does anyone use or recommend the MagPad w/MagPuck for lifting their cars ?
https://zl1addons.com/collections/ca...-3-jack-magpad |
05-08-2024, 06:33 AM | #2 |
Faster!!!
Drives: 2020 Camaro 1SS 1LE Join Date: Mar 2020
I use those for both my floor jack and when I use my Quickjack. They pop on and off easily, stay where you need them and work perfectly. Really handy when you go to shops to make sure they lift correctly. You can only see the bottom of the puck in the photo below (when I was installing my side skirts a couple of years back)
Definitely go for it! I prefer these over the premanent mounted ones. |
05-08-2024, 08:12 AM | #3 |
Drives: 2016 SS Join Date: Oct 2019
I have the four permanent pads/blocks on the four outermost lift points for using the quickjacks. I have a magpad that I use on the middle lift point for when I'm using a jack. Works great.
FWIW, I paid $11 for mine on Amazon. Doesn't have a name on the side of it, so they were able to save me $50 bucks. |
05-08-2024, 01:32 PM | #4 | |
Do you have a link ? |
05-31-2024, 01:51 PM | #5 |
Drives: 2023 Camaro 1SS Join Date: Apr 2014
I just received my 6th gen Stealth Lift Pads (in red) from ZL1Addons
https://zl1addons.com/collections/ca...alth-lift-pads So far, I'm impressed. I placed the order the day before yesterday and only paid for standard shipping. They're high quality, the anodizing is good, the screws appear to be adequately sized, and most importantly... THEY'RE MADE IN THE USA. $83 bucks for the real deal, made in USA.. Yep, you can spend $25, $35, $55 for 4 lift points on Amazon. Read the reviews. They're crap, and you're sending your money to China. Don't be that guy. |
05-31-2024, 02:31 PM | #6 | |
jfkheat
Drives: 2023 Rapid Blue ZL1 Join Date: Nov 2023
05-31-2024, 02:53 PM | #7 | |
And I just finished installing them over my lunch. Laid on the ground and fastened them down. Only took a few minutes. And now, it's ready to go up on the lift. |
05-31-2024, 04:10 PM | #8 |
Gray Ghost
Drives: 24 Camaro 2SS Loaded Join Date: Feb 2024
Purchased them and they are on there full time. I have not used them and the dealer uses the metal pads with their rubber blocks so they have not been used yet. HA!!!
For grins I tried the floor jack I have BUT!!!!! It is a shop floor jack therefore no worky because it does not fit under the car!!! I have only owned CrewMax trucks since the early 2000s. I have to purchase a new jack to fit under the car. YAY!!!! |
05-31-2024, 04:20 PM | #9 |
Tri-County Camaro SWFL
I use mine on multiple vehicles. I've used them on my 5th gen, wife's 6th gen, our last equinox lease, the current Blazer. They work great. I've also forgot to take them off on the 5th gen and have been over 130mph. Puck and pad were still on the car.
05-31-2024, 07:26 PM | #10 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
I had a similar incident. I did some late-night maintenance on the 2LS and discovered my mag pads still installed the next morning. Devised this little reminder to prevent a repeat performance.
06-01-2024, 11:52 AM | #11 |
Sharing a pic of the ZL1Addons Stealth Lift Points. They work really well.
Completed my 500-mile oil change yesterday evening, check fluids, drain/refill on the rear differential, and installed the CAGS eliminator. |
06-01-2024, 07:57 PM | #12 |
Drives: 2SS 1LE Join Date: Oct 2011
I love my jack pads from ZL1 add-ons. I change wheels from winter to summer and then every time now at autocross. Makes it a cinch.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
06-01-2024, 09:15 PM | #13 | |
EDIT* -So I went back and checked. They ARE Chinese. Buying American is good. Not gonna argue, but again, I'm not losing sleep. Life goes on. |
