Old 02-08-2018, 11:14 AM   #29
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
I have been hearing people who install the 2" have been melting the plug wires. Can someone confirm this? if so, what is the work around? I know there is boot/heat protectors, but some have been melting them too?
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 02-08-2018, 12:19 PM   #30
chrest
chrest's Avatar
Drives: 2017 Camaro 2SS
i just installed 2in TSP and the second primary is very close on both sides. i have the wire socks on mine but had the same clearance on my TBSS with socks and melted the stock wires.
They might be okay, but im thinking i rather be safe now then wait for the issue. i haven't ran the car long enough to have a problem but I will be getting MSD wires.
2017 NGM 2SS NPP M6 MRC
Vortech SC, 2" TSP LT No Cats, Borla X, Eibach,
Hurst shifter
603hp/547tq
chrest is offline   Reply With Quote
Old 02-12-2018, 08:17 AM   #31
2SSLOWW
2SSLOWW's Avatar
Drives: 2016 Camaro 1SS
I've been running the 1 7/8 headers with the stock sparkplugs. I can't remember which side but one of the spark plug boots will touch one of the headers causing it to melt a bit. However it doesn't melt completely through. I just wrapped the actual wires to play it safe. I've had them like that for about 16,xxx miles or so and still no issues.
Two things to look out for, 1) USE the steering shaft bolt that TSP provides and 2) be careful with the wiring harness on the on the passenger side. At least I think it was the passenger side. It will touch the headers which caused me some other issues.
Other then that I love the TSP headers. I received them within a few days and they sound great. Best bang for your buck. Good look with the install!
2SSLOWW is offline   Reply With Quote
Old 02-18-2018, 11:24 AM   #32
chrest
chrest's Avatar
I ran the harness up and over the reservoir. also, the bolt they provided me still hits. the threads are too long. I had to cut it down! I have the 2". I was so impressed with how easy they installed. I did have the tranny cross member unbolted for the hurst install simultaneously which may have made it easier. I would recommend doing that if anyone is having trouble with the passenger side. its super easy to unbolt.
Hurst shifter
603hp/547tq
Old 02-18-2018, 12:01 PM   #33
VAZL1
VAZL1's Avatar
Drives: 17 ZL1
Originally Posted by Tomiboy View Post
I think the "old stuff" had asbestos in it also
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp
VAZL1 is offline   Reply With Quote
Old 03-08-2018, 09:13 AM   #34
Hyper1SS
Hyper1SS's Avatar
Drives: 2016 Hyper Blue Metallic 1SS M6 NPP
Any pictures of under car install? Did you feed them from the top or bottom when installing?
2016 Hyper Blue Metallic 1SS M6 with body color hood vents, Silver broken 5 spoke wheels, NPP dual exhaust, Dark Night Interior Spectrum Lighting, Illuminated door sills plates.
Upgrades include: Roto-Fab intake, Mishimoto catch can, MBRP cat-back Race exhaust, TSP 1 7/8 headers, EFI E85 Flex Fuel, MRR M017 graphite wheels with Nitto N555 G2 tires, Goodridge stainless steel brake lines, Powder coated Brembo calipers, BMR suspension, Eibach sport springs, Emblempros fender badges
Order ID: TDHQMS
1100 on 01/07/2016 at Penske Chevrolet
6000 on 02/23/2016 Delivered to customer
Hyper1SS is offline   Reply With Quote
Old 04-10-2018, 10:19 PM   #35
FIFTY017
Drives: 2018 Silverado Z71 TxEdition
So i too have the 1 7/8 in headers along with 3 in xpipe. kept factory exhaust but had the tips powdercoated black. best decision i've made. was a pain keeping the chrome clean. I still have the rubbing issue only turning to the right. I'm reaching out to see what type of bolt is needed. my performance shop never received a bolt or 2 in the packaging when shipped. hoping this will correct the only issue i'm having with my baby.
FIFTY017 is offline   Reply With Quote
Old 04-23-2018, 12:15 PM   #36
DatBrotato
DatBrotato's Avatar
Drives: '18 SS 1LE M6
Just had the TSP 1 7/8ths put on, got them ceramic coated, I also used the supplied steering bolt.
0 rubbing issues. Plenty of clearance on both sides.
i'm not sure if there's a difference in the motor mounts used on the '18s. That's the only thing I'd imagine that would give me so much clearance
'18 1SS 1LE M6 NGM|| 11.5:1 Diamond Pistons || Callie's H-beams || Vengeance III Cam Kit || Built Heads || TSP LTs 1 7/8"(C-Coated) || MSD IM || DSX E85 || Rotofab || BMR Springs || 576/472 @7000rpm
DatBrotato is offline   Reply With Quote
Old 06-12-2018, 06:55 AM   #37
andes101
Drives: 2016 2ss
I keep hearing about the steering bolt rubbing issue, my Texas speed headers came with the silver bolt and a smaller black bolt, after install it looks like this, did I use the right bolt? Because I don't see how this could ever hit the headers especially since the bolt barely passes the column
andes101 is offline   Reply With Quote
Old 06-12-2018, 04:23 PM   #38
DatBrotato
DatBrotato's Avatar
zero clearance issues here with the supplied button bolt.
I drove around with em on for ~500 miles with lots of full lock turns, put the car on a lift and gave the headers a look over.
I couldn't find any evidence of rubbing or scratches on my ceramic coating.
Old 06-12-2018, 06:02 PM   #39
WhiteNight
WhiteNight's Avatar
Drives: MB 1SS
There may be a cradle misalignment. I have a set of 19s that have the same exact offsets, however one side pokes about .5 inches more that the other. Had the alignment checked twice and it's perfect. This was also an issue with GTOs.
WhiteNight is offline   Reply With Quote
