Old 07-21-2019, 10:05 AM   #1
Tyrolblue67
Drives: 2019 ZL1 Camaro
Wheel Balancing Question
Hi,
I recently installed a new set of tires.
I would like to remove the wheels from the car to clean the wheel barrels.
I noticed there is adhesive residue left on the barrel from the previous balancing weights.
It's kind of thick, about .5 mm and about 1/2 inch square.
Wondering if I clean/remove the old adhesive residue from the wheel it may mess up the balance of the wheel?
Thanks,
Tyrolblue67
Tyrolblue67 is offline   Reply With Quote
Old 07-21-2019, 10:13 AM   #2
No, that foam doesn't weigh anything. Use some goo gone and it will wipe right off.
Old 07-21-2019, 10:42 AM   #3
Tyrolblue67
Thank you.
Tyrolblue67
Old 07-21-2019, 10:43 AM   #4
Originally Posted by Tyrolblue67 View Post
Thank you.
Tyrolblue67
Old 07-21-2019, 04:29 PM   #5
VinnAY
Drives: 18 1SS/1LE
Yes googone and similar products will take that right off.
