01-16-2017, 06:54 AM | #29 |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
I was thinking about doing something like that myself. Good to hear it helps circulate the fluid.
MJK3888 Instagram Link
01-16-2017, 07:59 AM | #30 |
Drives: 2017 camaro SS blue w/white stripes Join Date: Nov 2016
is this the same process and oil type for a regular 2017 1SS? or is this only for 1LE's... Im confused!!!
01-16-2017, 10:07 AM | #31 | |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
The 1LE/ZL1 has a different diff than the standard SS, so it was a matter of confirming the fill/drain plugs and if there was any special procedure for the diff cooler.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
01-16-2017, 11:37 AM | #32 |
02-05-2017, 07:28 AM | #33 |
Nightfall Gray Blackout
Drives: 2016 Camaro 2SS Join Date: May 2012
Can we use Mobil one on a regular SS?
02-05-2017, 11:58 AM | #34 |
Drives: 17 SS 1LE Join Date: Dec 2015
I'd want to run synthetic fluid in the diff and transmission.. Think Motul 300 LS would be good? Don't know what to use for the trans..
02-05-2017, 12:45 PM | #35 |
According to the supplement the eLSD takes 5.4 oz of additive. I think that is 88900330.
02-05-2017, 12:58 PM | #36 |
Drives: ZL1 1LE Join Date: Oct 2016
Why not just use the AC delco lube w/ the additive already in it?
02-05-2017, 01:41 PM | #37 |
I took it to mean 1.6 QT of the 88862624 plus 5.4 oz of Dexron VI. The regular SS fluid capacities have no mention of the additive.
02-08-2017, 12:32 AM | #38 |
Drives: 17 HBM 1LE Join Date: May 2016
I agree, page 43 of the high performance supplement says 1.6qt with the elsd and below it 5.4oz elsd lubricant for ss1le.
02-08-2017, 07:23 AM | #39 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
I didn't think the eLSD fluid was supposed to be changed out though, just the diff fluid?
02-08-2017, 07:59 AM | #40 |
"M1SS1LE"
That's the way I took it too. I only put AC Delco fluid back in the diff. It took almost exactly 1.6 quarts.
02-08-2017, 11:01 AM | #41 |
I think the 5.4 oz gets added to the 1.6qt and it all goes in the rear diff? The H/p supplement specifically mentions the ZL1 and 1LE eLSD on page 43 .
03-27-2017, 03:20 PM | #42 |
Drives: 2017 SS 1LE Join Date: Feb 2013
I couldn't find a confirmation if the friction additive was required with the ACDelco fluid?
2017 SS 1LE (sold)
Nightfall Gray |
