01-11-2017, 02:59 PM | #29 |
Drives: 2017 2SS Join Date: Jun 2014
Guys - especially for us that are going to have our cars on the track, why even go with a catch can at all? Just eliminate the PCV system. Put a small filter up top, and vent the bottom tube under the car. Voila! No oil in the intake tract.
01-11-2017, 03:11 PM | #30 |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
I suppose I meant it didn't say desiel all over the bottle like the american oils do. I'm sure its very similar but it made me feel better. LOL!
MJK3888 Instagram Link
01-11-2017, 03:32 PM | #31 | |||||
I used to be Dragoneye...
So...no, just necessary for full track days. You'll never put that much heat into the oil at an autocross, unless there's many opportunities to accelerate on the track, or you run a great many heats in a row. Quote:
I'm fairly certain a few tracks I've been to require your PCV system to be in good working order (among other checklist items). Quote:
The integrated "catch can"...I believe GM refers to it as an "PCV oil separator" drains back into the engine, and reduces oil vapor ingestion FROM THE VALVE COVERS. There is still a PCV port that sucks oil vapors up from the valley of the engine. PCV system has two "sides" to it, but it's all "PCV"...the valve covers are sometimes referred to as the "clean side", and the valley as the "dirty side". So, some people feel its necessary to add a oil catch can, anyways. |
01-11-2017, 03:48 PM | #32 | ||
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
Better oil control and performance from a slightly [negative] pressurized system. |
01-11-2017, 03:52 PM | #33 |
Being a "diesel" oil isn't really a negative thing. They typically just have slightly higher zinc and phosphate levels, along with more/robust detergents and other addatives.
01-11-2017, 03:56 PM | #34 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
Not terrible by any means, but you could wipe it with your finger. And it would obviously continue to get worse if nothing was done...
01-11-2017, 04:40 PM | #35 |
Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
Perhaps some of those Dexos2 additives help mitigate valve carbonization.
01-11-2017, 05:38 PM | #36 |
Drives: 94z28 03z06 05 gto 02ss 16ss Join Date: Mar 2016
I've done , Watkins glen, Pocono. And pittsburgh international race complex, I'm my 2ss. I ran Mobil 5w40 but I also added an oil cooler. Oil temps never goes over 220 and water is 195. You need to watch oil temp more then anything with track days, I strongly sugest an oil cooler. Sure you can run you oil at 280 or 300 deg, but I'm not , 240 is on high end of recomonded for most all oils. In nascar oil getting to 270 and there in the radio with the engine builder biteing his nails
01-11-2017, 06:05 PM | #37 |
Drives: ZL1 1LE Join Date: Oct 2016
We have oil coolers from the factory, so that isn't an issue.
01-11-2017, 06:10 PM | #38 | |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
The Performance Supplement says the preferred oil for track is 0-40 or 5-40. The 15-50 is listed only if the 1st two are unavailable. A switch back to 'street' oil is only required if you used the alternate viscosity. As for DI build up, the quality of oil and fuel are of huge importance. Using good 93 and a top oil will dramatically reduce carbon deposits.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
01-11-2017, 06:17 PM | #39 | |
In terms of oil it looks like Motul X-CLean 8100 5W-40 will be good to go, as well as Mobile 1 ESP 0w-40 when it shows up on U.S. shelves, as they are both Dexos 2. I will most likely run one of these full time once I change at 1500miles.
01-11-2017, 06:33 PM | #40 | |
https://www.amazon.com/dp/B00JMCCE6U?th=1 This is all I have run in all my cars for 5 years. It's offered in a 0-40.
2017 HBM SS 1LE
01-11-2017, 06:41 PM | #41 | |
01-11-2017, 07:52 PM | #42 |
Drives: 2017 Hyper Blue 1LE Join Date: Dec 2016
I've been battling the catch can DI question for some time now. In the end with previous cars, worse case, I had the intake valves cleaned. Catch can won't capture everything, aren't cheap, require periodic servicing, and you'd still need a valve cleaning eventually. I doubt I'd put a catch can on. Let's face it, the fricking lawyers and people who have chosen to worship the environment over God have for some time now caused a lot of downstream issues for everyone due to their obsessions. I'm probably going to do what I've done with all my previous cars - drive it and enjoy it. What's the worst case? You get the joy of taking the top of your engine off, cleaning it, and having the satisfaction that you've done something for your car and yourself. How is this any different than shelling out $300 or whatever a CC costs, installing it, then dumping the thing every month or so? Well, the difference is the frequency in which you do the maintenance.
