08-27-2021, 10:57 PM | #57 |
ZL1 Believer
Drives: 2019 Camaro ZL1 Join Date: Oct 2020
I also tried to reach Ted a few times and when he found out, he had me call. I had everything taken care of concerning my ordering from him.....
09-10-2021, 05:23 PM | #58 |
Drives: ZLI 1LE; 992 S; GLE 450, Denali HD Join Date: Sep 2019
Outstanding Experience
Thanks to the testimonials on this thread, engaged Ted for remote tuning.
My car was just not right after instlling cam, 103 TB, ported stock SC. This is a track car; was never happy since the mods. My laptimes were off ever since the upgrade and drivability was aweful. Local shop that did the work was busy and in the middle of a shop relo so I couldn't get this resolved in a reasonable amount of time. Figured I had nothing to loose since the car just garaged because of the issues. So I signed up for remote tuning. WHAT A GREAT MOVE. This car now has the all the perfromnace I had hoped for with the upgrade investment! Ted was very methodically and responsive. He diagnosed shot high flow cats and fuel pressure issues. I am very impressed. Each step of the way, he would detect issues based on the log files I sent and recommended I check the mentioned issues. Each time, he was spot on - the issue he detected were actual problems. I was able to address myself or through other local shops. Once addressed, we proceeded to improve the tune. I took the car back to my home track to log his final tune and 1/10 off my fastest time, in the hot weather and worn tirnes too. This is more like it! My advise to anyone who uses Ted; You will not be disaapointed and act on his recommendations! Thanks Ted - increadible job! |
09-10-2021, 05:40 PM | #59 | |
Shadow Gray '19 ZLE M6
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
09-10-2021, 07:23 PM | #60 | |
Now with that said, LEAVE THE MAN ALONE ALREADY SO HE CAN WORK ON MY CAR!
09-10-2021, 07:30 PM | #61 |
Drives: 2019 ZL1 Join Date: Mar 2019
LOL!
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
09-11-2021, 06:32 AM | #62 |
Drives: 2017 ZL1 Join Date: Apr 2020
Ted is the man !
2017 ZL1 M6 Silver Ice Metallic
09-11-2021, 06:40 AM | #63 | |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
09-11-2021, 07:03 AM | #64 |
I command .82 and achieve .82
www.jannettyracing.com
09-11-2021, 07:09 AM | #65 | |
Following my instructions made it a breeze to work through all your issues. This is one of the hurtles I run in to with some of my customers, seems they refuse to read the instructions I provide. You also knocked it out of the park. Thank you for your business and look forward to working with you again. Ted.
09-11-2021, 12:13 PM | #66 |
Thanks for the info, appreciate it.
Forgot to ask if that is based on Original tune Stoich (14.1)or did you change it to 14.7?
09-11-2021, 06:57 PM | #67 |
Ted, have any of your customers with 2650, cam, aux pump or jms, etc..added e30 or e40 to the setup with good results?
09-11-2021, 08:58 PM | #68 |
If the car is setup to run E, stoichiometric is set for 14.7 at 0% E, and scaled accordingly. Otherwise the car is set to 14.1 across the board and that would obviously not work. Lol
09-11-2021, 09:09 PM | #69 |
I'm not set to run e. I was curious if he changed the stoich from factory 14.1 to 14.7 when he said he tunes to .82 lambda. Cause 11.5afr seems rich but 12.0 i think is reasonable, but I could be wrong.
09-11-2021, 09:16 PM | #70 | |
If you do install the E sensor, then you MUST rescale that table. .82 Lambda works in both cases.
