05-25-2018, 07:21 AM | #99 |
I don't think there is a 100% verdict and LT1Z350 did log some changes.
IMHO: I think that if the screw is too far in then you are losing some boost. If not then the screw position does not matter. I tried drag racing with the screw slightly pushing the arm, just touching, and then with a gap. My MPH was consistent in the same DA. 123-126 depending on the DA +1500 to -1250. It is also possible some A10s are faster than others or track MPH numbers vary by quite a bit. My car will never see 128-9 MPH @ Atco. But it only has 2,000 miles on it so it might loosen up a bit. But judging by what I have run so far 11.4 with a high 1.8 60' If I can get one of those very rare stock 1.6 60s in good air my ZL1 is capable of 11.0s. So even at my MPH there is hope for a 10. More seat time is the plan and good air, good track prep and maybe a tailwind will get me there. LOL And the low MPH numbers we see on the fast list might be caused by the screw in too far, or they used launch control. My MPH at Atco using LC was 121-122. For good times all nannies off should be the plan with the not pushed in too far blower screw setting. Opinions may vary.
06-09-2018, 02:57 PM | #100 |
Drives: 2018 ZL1, Cadillac ATS-V Join Date: Feb 2018
I just saw my SC, and you can see the mark on the lip.
06-10-2018, 12:57 PM | #101 |
Today I done WOT and the needle was between the 3rd and 4th mark.
Tomorrow I will adjust the screws and check again. Just fast hp tuner question: What parameter I have to check for boost in scanner? |
06-11-2018, 02:35 PM | #102 |
ok I did turn 1/4.
the boost didn't change much, but it sure get better acceleration. it seems that its controlled by ECU. |
06-12-2018, 07:20 AM | #103 |
I want to believe. Read all this again. I think the only sure fire way for someone to tell a difference is data logging as the OP did or back to back dyno runs.
There are too many variables at the track except MPH same track same lane, same DA. But OP is your sig saying you ran 10.80s@131 all stock in your ZL1? Also those 120-122 mph ZL1 runs also can be high elevation, extremely high DA, launching with launch control, or letting your foot ever so slightly off the load pedal during the run. Ask me how I know about that last one. Coming off a bunch of M6es there is not much to do after the launch in an auto except stay in your lane and keep your foot planted. Is muscle memory haunting me? Heading back to Atco again tonight. Any ZL1s out there going? We could fool with our boost screws and compare notes. It will be a good weather night and good track prep.
06-12-2018, 08:10 PM | #104 | |
06-12-2018, 09:52 PM | #105 | |
Drives: Grandad's C2 L89 Join Date: May 2017
+1. Bravo!
2018 ZL1 1LE sw/PDR
06-27-2018, 01:36 PM | #106 |
Drives: 18' A10 ZL1 , 18' F150, 04' MSM Join Date: May 2018
I found this thread after noticing that my factory boost gauge was never getting past the 7.5 PSI mark.
Made the adjustment and it is definitely going past it now. Obviously not scientific, but the car feels faster, and low speed WOT pulls the car seems to be struggling a bit harder for traction. My screw was adjusted in pretty far, over a full rotation for sure. I left basically enough room to slip in a piece of paper but that's it. The PDR videos will show boost when opened with the cosworth toolbox right? I want to look at the data to see if I'm just crazy. |
06-27-2018, 02:45 PM | #107 | |
@zle_blackwing
Drives: 2018 ZL1 1LE Join Date: Mar 2017
06-27-2018, 02:50 PM | #108 |
I've got some PDR footage from before I made the adjustment so I can compare.
06-27-2018, 02:53 PM | #109 |
@zle_blackwing
That would be great. I'd be very interested in that comparison. Thanks!
06-27-2018, 09:29 PM | #110 |
Compared a few PDR's from before and after and it looks the same to me.
Max boost was usually 10.4 with one instance of hitting 10.5. I think the factory gauges lag behind a bit so they're hard to read when accelerating that fast. |
06-28-2018, 07:04 AM | #111 |
@zle_blackwing
Thanks Joe!
06-28-2018, 08:30 AM | #112 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Finally got around to seeing what mine is at stock. Here is a pic. Is this where most of you were at stock?
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
Tags |
adjustment, boost, bypass, lt1z350 |
