03-28-2021, 09:58 AM | #1 |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
Gas Cans/Jugs for track
So im interested to see what guys are using to take gas/E85 to the track? I have a couple of options but not sure which is the best one. So would like to know what guys are using or opinions.
1. https://www.justrite.com/7250120-typ...se-red-7250120 Looks like a great can just expensive. Also has more of a old look to it. 2. https://vpracingfuels.com/product/vp...ntainer/?c=237 This looks like what most guys use just don't like that you have to open the vent up before pouring,also it's pretty tall. 3. https://vpracingfuels.com/product/vp-surecan/?c=237 Looks like a great option but not to sure how long the gasket will last on the bottom of the can. |
03-28-2021, 10:12 AM | #2 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
I've got a couple of the VP's. The vent is only a minor hindrance. You can crack it a half turn or so until the fuel level in the jug drops just a bit, then loosen it several turns. Only spill a few drops in a typical fill up.
Baby Blue
03-28-2021, 10:13 AM | #3 |
I have a bunch of 5 Gallon clear jugs like the ones you buy from Summit, Jeg or VP. Just make sure you take your slide in funnel that came with you car.
03-28-2021, 10:17 AM | #4 |
03-28-2021, 10:18 AM | #5 |
The VP can don't fit in the trunk correct?
03-28-2021, 10:28 AM | #6 |
Drives: 2017 SS 1LE Join Date: Mar 2017
You don't want the store gas in your trunk.
03-28-2021, 10:30 AM | #7 |
Drives: 2020 Camaro ZL1 1 LE Join Date: Mar 2021
I use the VP racing jugs (middle link). I take about 8 with me to the track in my trailer.
I like that they have a large mouth and that the gasket on the cap seals well. the air vent cap has not been an issue for me. there's no way you are fitting those in the trunk of a camaro though. you will need a friend to bring them in his pickup/minivan (or you can get a small tire trailer to tow behind your car; i've seen that done too) |
03-28-2021, 10:40 AM | #8 |
So I have to use Uhaul trailer as I have no place to park a trailer if I purchased one. Uhaul trailer has no place to put cans. I have a X7 that I was going to tow with.
03-28-2021, 10:43 AM | #9 |
Also read that the VP jugs are not for transporting fuel. What's the deal with that BS. Let me guess some EPA shit.
03-28-2021, 10:58 AM | #10 |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
VP jugs are the best, great bundle deals on EBay. I get the white ones because you can see fuel level easy through side. The standard hose spout does fit in the ZL1 tank. What doesn’t sometimes fit are pump spouts at the track.
VP also makes a stubby 3 gallon can that can fit in the trunk without spout attached, I saw a guy show up at track with at least 4 in his trunk. https://vpracingfuels.com/product/3-...ntainer/?c=237 Get some of these cargo supports to hold them in place. https://www.weathertech.com/cargotec...CABEgLRKfD_BwE |
03-28-2021, 11:33 AM | #11 |
It's probably not advisable, but if you fold down the back seat, two of the standard size VP jugs fit just fine
Baby Blue
03-28-2021, 03:46 PM | #12 |
Drives: 2017 ZL1 Join Date: Aug 2020
I bought a couple of the yellow lower profile 5 gallon jugs off Amazon for ethanol and they fit in the trunk great and come with a built in nozzle.
03-28-2021, 03:55 PM | #13 |
03-28-2021, 07:27 PM | #14 |
