10-01-2018, 11:00 PM | #43 |
Drives: 2SS 1LE Join Date: Oct 2011
lol, a RWD car with massive power and little weight on the rear axle. It literally doesn't get any worse than that for winter driving. Just being able to start in an intersection in the winter can be a major feat and being able to travel at more than just 5mph is necessary to drive on public roads.
This isn't the same as a bigger vehicle with more weight over the axles. Sorry, live in Alaska and drive in winter. While there are some things you "can" do, you aren't impressing anyone but yourself by doing something stupid. There's always someone that claims they drive in the winter on racing slicks and that it's "totally fine".
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
10-03-2018, 06:10 AM | #44 |
Drives: 2018 SS 1LE Join Date: Sep 2018
It is relative, Alaska is probably the extreme in this case. I technically live in the south (Maryland). We get maybe a week of snow actually being on the road. It is mainly either getting caught going home or the morning after. If it is to bad my work is canceled anyway. For me winter driving is mainly dry cold weather traction, oh and the ridiculous amount of salt the put down.
When I lived in Oklahoma I didn't even bother. Any snow was normally gone by noon. My last three cars have been 2 Evos and a Focus RS, all with snow tires, I always looked forward to snow to have to fun, now I will have to be a bit cautious. |
10-03-2018, 07:32 AM | #45 |
Drives: 1SS 1LE Join Date: Mar 2018
Im going all seasons. Not looking to take out the camaro when its snowing out but if I have to use it for some reason at least it will get me there, slowly...
275/30/20 front 285/30/20 rear
What this car really needs is a notification eliminator. There's a wi-fi notification. Bluetooth notification. Parking brake disabled notification. Always some annoying notification popping up. - Navigator post
10-03-2018, 09:19 AM | #46 | |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
Reddy, I'd go square on aftermarket wheels. You'll be able to rotate them and retain full tire warranty. |
10-03-2018, 02:12 PM | #47 |
Razzi
Drives: 99 Monte Carlo Z34 Join Date: Jul 2008
Thanks for all the comments. I live in Indiana and don't plan on driving while its snowing or freshly salted just want to be able to drive when its below 40 outside and the roads as clear. When its snowing or the roads are crap I plan on driving my beater.
10-07-2018, 06:08 AM | #48 |
Drives: 2019 SS 1LE Join Date: May 2016
Hey guys, looking for some advice.(First time buying winter wheel/tires)
Will I have any problems with 19x8.5 30mm offset 245/45/19 |
10-07-2018, 06:20 AM | #49 |
Thank you Al Oppenheiser!
10-07-2018, 10:31 AM | #50 |
Drives: 2017 SS 1LE Join Date: Jan 2018
Picked these up the other day. 18x8.5 ET20 BMW wheels. Plenty of clearance on the face and enough room to the barrel that I'm not worried about it.
10-07-2018, 10:34 AM | #51 | |
10-15-2018, 10:04 PM | #52 |
Razzi
Does anyone see an issue with this square setup?
CURVA C300/ Rim Diameter: 19 Rim Width: 10 Offset: 30 Bolt Pattern: 5x120 Hub Bore: 73.1 Front Setup Rear Setup |
10-16-2018, 06:44 AM | #53 |
