11-04-2021, 06:30 PM | #15 |
Jewl so your converter is making up for low end loss(if I understand what you said) how would a stick car make up for that loss?
Orange Krush II
11-04-2021, 07:37 PM | #16 |
Yes, my converter flashes up to 6k when I get on it and when it drops back down in the downshift 1000 or so rpm's, it puts me right in the middle of my power curve, 4800-7500 and makes up for the low end TQ loss that would normally be there "uncammed" and stock converter. I see you are running a 3.91 gear already, my guess would be a 4.10 gear to get the revs up higher in your powerband to get a better launch. I think that is the only way to multiply the TQ you have with a stick car. I believe ACAMMER who is a member here and either does still, or did work with GPI and he is running a 4.10 gear last time I saw one of his posts. Back in the day I used to run a 4.56 gear in my 340 built Challenger to get it going, and a couple of my buddies with Road Runners 4 speed cars. You would run out at the top, but you sure got out of the hole quickly. Just my .02.. I'm not a pro at this by any means. But I've been around.
11-04-2021, 08:30 PM | #17 | |
11-05-2021, 11:17 AM | #18 |
Good luck brother! I hope that it was just a "6l80 glitch" and that there is nothing wrong. Like I said, it's been a looonngg time since mine did it..
11-05-2021, 12:15 PM | #19 |
Drives: Camaro Join Date: Oct 2018
Few years. Are you really only making power to 6100 with the ss1 cam? Id assume you'd be making power past that just based on my old v2 cam. I flattened off but still could take it well past 6100 then as well
11-05-2021, 04:49 PM | #20 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
Well it carried the power to almost 6400 rpm and at 6700 I could hear it losing power almost nose diving. I think my next mod will be an intake and throttle body and that will let me get into the higher rpm range. I just don't see any point to revving it that high right now.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
11-05-2021, 05:01 PM | #21 | ||
11-05-2021, 05:03 PM | #22 |
Yeah I just watched that yesterday. lol. Thanks though buddy 👍
11-05-2021, 05:05 PM | #23 |
Very cool, you're welcome sir!! When I called and talked to Ryan after I saw the video and asked why he didn't do a stock TB on the LOD, he said that they didn't get it there in time to do the 92's, but just the 102 TB's.
11-06-2021, 10:05 AM | #24 |
Drives: 2014 Camaro 2SS Join Date: Oct 2017
Ryan did the same with mine as well 7200 rpm. Idk about you guys but I honestly felt like the car wasn't really pulling hard after 6500 rpm so as it climbed up to 7200 it was just making a lot of noise and not really going anywhere lol.
I looked at my dyno sheet one day and it looks like it peaked power at 6200 rpm. I had him adjust the tune to bring it down to 6400 rpm. This was when I was still NA.
Mods: GPI SS1 VVT cam, TSP long tube headers, LSA conversion, ZL1 fuel pump, ADM FPCM, DW 700cc injectors, Lingenfelter solid isolator, Dedicated Motorsports ZL1 reinforced brick, ADM Griptech 2.5 pulley, JLT CAI, Phastek intake scoop, NPP cat-back, GM 3.91 gears, Eaton Truetrac, Tuned by Chris @ CHenry Motorsports.
11-06-2021, 11:32 AM | #25 |
GPI Sales Consultant
SS1 VVT will peak around 6100rpm, but it hangs on real good after that to about 6600, and starts to roll over. With a stock torque converter you need to shift it around 6800 to keep shift recovery in a good place - with a higher stall you could probably shift it a bit earlier as it won't dip so far on shift recovery.
7200rpm is ZERO concern for the bottom end on these combinations. With BTR660 platinum springs and Ti retainers, it also is zero concern for the valve-train. 7200rpm wouldn't make sense for the shift point with that cam, but it makes complete sense for the limiter. Unbeknownst to some, you don't always get your commanded shift point RPM to actually happen in real life. You may command the shift at 6700rpm, but on the 1-2 it may come up so quickly (especially if wheel-spin is involved) that it will overshoot the target by a good amount. You've got to have some room between the commanded shift point and the rev limiter, or you'll find yourself into the limiter some times.
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message! |
11-06-2021, 11:49 AM | #26 |
Now that's the kind of answer I was looking for. Solid advice from a professional. Thanks buddy for the clarification I really appreciate it. Thank you.
11-06-2021, 02:21 PM | #27 |
Drives: ABM #93 Join Date: Oct 2018
Awesome post acammer! Makes perfect sense.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
11-06-2021, 05:11 PM | #28 |
Perfect explanation. Thank you!
