11-20-2018, 10:23 AM | #1 |
Drives: 2017 2ss Join Date: Aug 2018
Alternator question
Hey folks. I've had my 2ss for 3 months now and am head over heels in love. One interesting thing I have found is the varying voltage in the car. I have a radar detector that reads voltage in addition to the "gauge" in the DIC. At times they read as high as 15 volts, other times as low as 12.4v Every other car I've had the voltage remains constant when running between 13.5 and 14. This may be a really dumb question, but does the alternator/regulator vary output depending on conditions such as accessories or additional load? I do not have any amps or other items installed except the detector. Thanks!
11-20-2018, 10:48 AM | #2 |
Opus13
Drives: 2017 Camaro 1SS, Black Join Date: Jul 2017
Yes, the regulator varies the voltage. There are posts here more about this.
I freaked out the first time I noticed the gauge reading lower than 14 volts.
"My entire life in one sentence:
It didn't go as hoped, but that's okay" Opus ie. Berkeley Breathed. |
11-20-2018, 10:51 AM | #3 |
In a word, yes. These new charging systems have a much wider range and are more intelligent. Unlike the older ones that just charge at a specific rate.
Took awhile to get used to! |
11-20-2018, 10:56 AM | #4 |
What the system is really doing is trying to reduce engine load to improve fuel economy.
https://www.redarc.com.au/alternator...xed-alternator |
11-20-2018, 02:16 PM | #5 |
Drives: 2019 ZL-1 Join Date: Feb 2009
Numerous threads on this...
2012 Yukon XL Denali w/ 6.2 AWD |
11-20-2018, 03:18 PM | #6 |
Drives: Chevy Blazer Join Date: Sep 2009
PITA... Been on the half-tons since 2007, lol. Gotta disable that crap, like I did on my old truck, lol
Sent from my SM-G930W8 using Tapatalk |
11-21-2018, 06:29 PM | #7 |
Drives: 15 SilveradoLTZ,162SSVert BlazerRS Join Date: Dec 2015
Why would disarm this system? It improves fuel mileage, Gives You More HP, and has NO other dis-advantage's
11-22-2018, 09:41 AM | #8 |
Negligible amounts of either, lol.
It's fine until you load it up with a sound system. Sent from my SM-G930W8 using Tapatalk |
