09-07-2014, 10:26 PM | #1 |
Drives: 2011 LS Camaro Join Date: Mar 2011
Adding SS wheels to my LS
I will be buying some SS wheels for my LS. Besides tires, do I need to remount/rebalance them? I am getting new tires for them. Also how about the TPMS?
Exhaust: Magnaflow catback/x-pipe, Injen SRI, BBK Headers w/ no cats
Suspension: BC BR Coilovers Cosmetics: ZL1 front conversion, AAC plasma afterburners 2.0, GFX rear, Interior: AAC red footwells, ZL1 shifter boot/knob, suede center console |
09-07-2014, 10:54 PM | #2 |
Drives: 2014 AGM 2SS/RS 1LE Join Date: Aug 2013
If they have tires already, you might be fine without re-balancing them but it couldn't hurt. As far as the TPMS goes, I think you have to have the sensors programmed to the car by the dealer unless someone here has a DIY post for doing that.
2014 2SS RS 1LE
09-08-2014, 12:41 AM | #3 |
Drives: 2012 LS Join Date: Apr 2013
Yea can't hurt to just have a place throw them on the way they are and fix the balance if needed... I did the swap to my ls and my 2012 I just needed to deflate them to like 20 and then back up to 35 and they relearned by themselves no tools or anything I do believe you have to go to the screen with the pressures and hold set or something like that
09-08-2014, 01:20 AM | #4 |
Would rather be riding
Drives: No car no more Join Date: Jul 2009
You have to remove the tpms sensors anytime you dismount a tire. That breaks the valve stem off them 75% of the time so that's nothing unusual replace all 4 of them anyway, cheaply. Or the more expensive route would be buying 4 new sensors.
On a 2011 I believe you can still program your TPMS system without any special tools. If you are able to the owner's manual for your car will contain instructions on how to do so.
No dog in this fight anymore.
5th Gen owner 2009-2016. |
09-08-2014, 10:15 AM | #5 |
Drives: black and silver Join Date: Apr 2014
why buy ss rims. make it your own
09-08-2014, 10:48 AM | #6 |
Can i get tpms at discount tire?
09-08-2014, 12:16 PM | #7 |
09-08-2014, 11:04 PM | #8 |
Can i just take the rims in for tires and put them on at home?
09-09-2014, 07:27 AM | #9 |
09-09-2014, 07:43 AM | #10 |
Drives: 2011 SIM 2SS/RS LS3 Join Date: Sep 2013
He means get the tires mounted and put the wheels on the car at home....
2011 2SS/RS built 8/24/10
09-09-2014, 07:56 AM | #11 | |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
If your taking the tires off your stock wheels as well, you can use those TPMS, but be sure to keep track of where they came off of. As mentioned the valve tends to break when they remove the tire, but it can be fixed for a few bucks each. If you use the TPMS from the SS wheels (if they come with TPMS units) you will need to do a relearn. http://www.camaro5.com/forums/showthread.php?t=170203 If you get new TPMS they are $35-$40 each.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
09-09-2014, 11:49 AM | #12 | |
I'm still not 100% sure what "them" meant, so can't say I agree with you on that... You can get TPMS on amazon for about $30 each or eBay for $15-20 each (even less if you buy a set of 4). Buying from the dealer/shop will run you a premium. http://www.camaro5.com/forums/showthread.php?t=375753 |
09-09-2014, 05:27 PM | #13 |
Montani Semper Liberi
Drives: 2011 Black 2SS/RS w/ IOM stripes Join Date: Feb 2010
I know when I bought SS wheels and tires off this site they were practically the same circumference as the 18's I had on my 1LT at the time. so didn't need to flash anything to get them to work with the car. never had an issue the 3.5 years I had it.
Stainless Works 1 7/8 Long Tude Headers, Stainless Works High Flow Cats, Stainless Works Retro Chambered Catback, Z/28 Air Intake, RDP Tuned, FR41 Chrome Rims, 1100W stereo, 35% Tint |
09-09-2014, 05:44 PM | #14 |
100% Sport Møde
Drives: '17 Civic SI + '04 SVT Lightning Join Date: Apr 2012
