09-03-2019, 04:03 PM | #1 |
Drives: 2022 Wild Cherry SS Join Date: Aug 2012
NPP Settings
If I set the NPP in Stealth mode for startup do I have to reset it when I want to go into Sport mode or will the valves open above a certain rpm Thanks!
09-03-2019, 11:05 PM | #2 |
Drives: 2010 camaro RS,2017 camaro 1Le Join Date: Mar 2016
once you set It in engine sound management it will stay in stealth mode until you choose another mode. the only way the valves will open and close is if the auto option is chosen under engine sound management
2017 camaro 1le
ROTO fab, Ported MSD, Ported 95mm tb, 2in TSP catless longtubes, flowmaster x-pipe, flowmaster American thunder npp, flex fuel, |
09-04-2019, 11:24 AM | #3 |
That's what I was thinking and thanks for the help!
09-04-2019, 12:07 PM | #4 |
Drives: 2019 ZL-1 Join Date: Feb 2009
The valaves will open after 4000 rpm.
2012 Yukon XL Denali w/ 6.2 AWD |
09-20-2019, 07:12 AM | #5 |
Drives: 2018 Camaro SS Join Date: Feb 2016
Is there anyway for me to mate the Stealth mode exhaust setting to the Touring Mode so that I can just use the switch?
Current - 2018 Camaro 1SS with MRC, 1LE Suspension, NPP Exaust, 6 Speed.
Past - 2016 Ford Mustang GT Performance Pack 2015 Camaro SS 2010 Ford Mustang GT |
09-20-2019, 08:17 AM | #6 |
No, the predefined modes cannot be edited. All you can do is, as you probably know, set up a single custom "mode" with explicit settings, but even that can't be saved as a profile. ("Z" mode, oh well.)
09-20-2019, 08:27 AM | #7 |
Snow and Ice is Stealth mode.
2016 NFG 1SS A8
09-20-2019, 09:12 AM | #8 |
Bet he just wants the stealth exhaust setting and not the extra torque management from S/I mode
09-20-2019, 10:33 AM | #9 |
Drives: 18 1SS 1LE HyperBlue Join Date: Aug 2018
Well if you have HP tuners you can change it in the body computer, but you need to unlock the credits to do it.
One trick I was shown is that you can actually put the car in accessory mode (hold the start button down 5 seconds so it turns the ignition on but not start the car) and you can then set the valves to Stealth before you start it. Then put your foot on the brake / push the clutch in to start there car. Its the only way to start the car with the valves closed.
2018 1SS 1LE / HBM - ECS Novi 1500 S/C Tuned by Carl @ CJ Tunes
09-20-2019, 10:55 AM | #10 | ||
While I know this to be true, when I put the car in Snow and Ice mode it doesn't start in Snow and Ice mode (when I park my car overnight then start it up the next morning). It defaults to Tour, which has the same initial start up as Sport (before quieting down). I want to make the exhaust louder, but I have to mitigate the noise in the garage.
09-20-2019, 01:49 PM | #11 |
Well then you need a tune to do what you want. We have full control over the NPP settings per mode with HPtuners.
2016 NFG 1SS A8
09-23-2019, 07:51 AM | #12 | |
That is great to know. I appreciate it!
09-23-2019, 09:22 AM | #13 |
Yea and you could do it without voiding your warranty because you don't need to flash the ECM to change the NPP settings. Just license the FSCM controller, change settings, and flash.
2016 NFG 1SS A8
09-23-2019, 09:50 AM | #14 | |
Thank you so much
