12-23-2019, 12:55 AM | #1 |
Drives: truck Join Date: Oct 2010
2650 on LT4 with 91oct?
I am wondering if anyone has seen or could accurately speculate a lt4 with minor to no other upgrades would make with just a 2650 swapped onto it? Considering the gt500 is making pretty close to 800 flywheel and high 600’s to the wheels as well as trapping 133mph on pump gas. I wonder what the LT4 would do with the same size blower on pump.
12-23-2019, 06:32 AM | #2 |
That's 800 crank hp which is probably around 675 at the wheels. You should be able to get pretty close that et with one of our 2650 Magnuson's with drag radials and a tune. Mike Sitar's sons 18 SS was bone stock except for the 2650 and his went 10.80s on 7-8 lbs of boost with 20" drag radial on 91 octane on the stock canned tune.
12-23-2019, 06:54 AM | #3 |
Drives: 2019 ZL1 Crush Join Date: Jan 2019
670WHP with just an eforce 2650 and a tune here. 91 pump only
2019 Crush A10
E-Force 2650 670WHP 615WTQ All besides the 2650 is bone stock down to the air filter. |
12-23-2019, 10:18 AM | #4 |
Drives: ZL1 1LE Join Date: Oct 2018
I’m running a 2650 on an otherwise stock ZL1, with the Magnuson tune and on 91.
12-23-2019, 12:40 PM | #5 | |
Dyno Show Queen LOL
Take a look at both 2650s available and see how you plan to fuel them before you choose one or the other.
12-23-2019, 03:51 PM | #6 |
Stock LT4 blower, headers, rotofab, and E50 will make 670-690whp depending on Dyno. You don't even need a blower swap for that power level, just some simple bolt ons.
2016 NFG 1SS A8
12-23-2019, 05:19 PM | #7 |
Not looking to make a certain number. Just wondering what the Lt4 would make if it was running the same size blower as the mustang. Sounds like it’s pretty similar.
12-23-2019, 05:33 PM | #8 |
You can easily make what that Mustang does.
12-28-2019, 02:48 AM | #9 |
Drives: 2015 C7 Z06 M7 Join Date: Dec 2012
My Z06 makes 729 to the tires on 91 octane with a 2650. stock lt4 and all stock exhaust.
12-30-2019, 04:21 AM | #10 |
Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
What boost/pulley are you running? That’sa really nice target for the street.
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
12-30-2019, 09:49 AM | #11 |
Russ I believe he was on the 80 mm pulley and if I remember correctly about 14 lbs of boost
12-30-2019, 05:16 PM | #12 | |
As t strong enough.
12-31-2019, 05:03 PM | #13 |
Based on Mike’s numbers, sounds like the 80mm pulley, 103mm tb/snout, Rotofab, and updated tune are the way to go. It’d be another 90-100hp and I’d be done...
When can I drop it off in Ventura??? |
12-31-2019, 07:09 PM | #14 |
Yup and have a fast ride for sure.
