04-24-2018, 08:58 PM | #1 |
Drives: 2018 2ss 1le Join Date: Jan 2018
what could you expect
what could i expect from a roto fab dry, pray ported intake and t/b , and a tune...
anybody dyno a combo like that on an m6 |
04-24-2018, 10:36 PM | #2 |
Instagram- _2sslow_
Drives: 2016 Camaro 2SS Join Date: Dec 2015
Recommend getting headers and flex fuel sensor to make power
Instagram- _2sslow_
2011 Camaro LT RS (Sold) 2011 Range Rover Sport HSE (Sold) 2016 Camaro 2SS NPP, TSP headers & Xpipe, Skid e85, CAI Intake, MSD IM, 95m TB, BigPowerRacing Tune, H&R Lowering springs, BMR sway bars |
04-24-2018, 11:27 PM | #3 |
BAMF SS
I would guess 440ish on a dynojet, sae
04-25-2018, 06:39 AM | #4 |
don't want e85
not sure about headers... don't want to move stock cats and then there the whole warranty thing... i am pretty sure i can get away with the tune... (it seems to me that no one has actually had a warranty claim denied because of a tune... i have asked around and no one seems to have had that happen to them, and any tuner you speak to says they have never had an issue) don't think they will notice throttle body and intake (i plan on buying a stock throttle body to throw on if needed) cold air wont void any warranty... it may seem silly but i have this idea that id like to make 500 at the crank.... i feel like these mods will get me there "440 ish" at the wheels should be right about there .... |
04-25-2018, 08:33 AM | #5 |
I'm guessing you will pick up 25-30whp with those mods. You could also do the CA performance test pipes that bolt in place of your factory cats. That would be worth another 10-12whp if you don't have to worry about emissions.
2016 NFG 1SS A8
04-25-2018, 10:49 AM | #6 | |
Drives: 2017 1SS Camaro; 2016 4Runner Join Date: Dec 2016
If you get a tune, assume you are running without a warranty. |
04-25-2018, 11:27 AM | #7 |
but do you know of anyone personally that had a claim denied because of a tune
and just a tune...? no e85 headers or other obvious signs of tampering? in have a 2012 grand Cherokee that went in for multiple engine related issues and the tune never came up.... everyone on those forums said the same thing ... tune voids warranty yet never had that issue |
04-25-2018, 11:33 AM | #8 | |
Drives: 2017 Camaro Join Date: Mar 2018
04-25-2018, 12:20 PM | #9 |
any way back on topic....
has any one dynoed that combo? |
04-25-2018, 01:40 PM | #10 |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
You can stick your head in the sand but if a major drive component fails your kidding yourself if you don't GM is gonna request a screenshot of the current calibration verification numbers from the dealer your very mistaken. Yes I do know someone who has had their warranty denied because of that on an ATSV everything returned to stock configuration including the original saved file that came off the ECU. Once the calibration that left the factory is changed its a wrap. I'd expect to see in the the 20-25 wheel area from the mods you listed.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
04-25-2018, 01:55 PM | #11 |
out of curiosity...
was his tune the cause of the failure and if not then I'm of the understanding that even though a lawyer may need to get involved, they have to prove the damage was caused by a tune? |
04-25-2018, 02:30 PM | #12 | |
Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
Some dealers are cool, and some are real sticklers about it
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
04-25-2018, 02:52 PM | #13 |
The PCM controls every part of the powertrain, so by changing it they can deny coverage. You could try and fight it but there is no repair large enough to justify you trying to battle it out with GM's lawyers. You'd be tied up in court for years and go broke.
04-25-2018, 04:07 PM | #14 |
Drives: '16 2SS / '05 SRT10 Ram / '65 bu Join Date: Dec 2015
A tune on 93 pump gas with the accessories you mentioned will not gain you much. Unless you want to go the e85 route than I would suggest staying stock with the PCM.
