01-24-2019, 12:22 PM | #15 |
Drives: 2017 SS 1LE Join Date: Mar 2016
it varies based on the track, for example last year I did $35k for every event, VIR was $200, NJMP was $200, but Summit Point was $250 because that track has more incidents than most.
IG: @NC_M1SS1LE
01-24-2019, 05:10 PM | #16 |
1LE Convert
Drives: 2018 ZLE Join Date: Apr 2017
I keep a plastic container in the garage with most of the things I bring with me to the track, ready to go. Here's my full list.
--- DRIVER --- - Helmet - Head sock - Gloves - Driving shoes - Sunglasses - Long-sleeve shirt - Long-sleeve jacket - Long pants - Sunscreen - Water --- TOOLS --- - Tow hook pre-installed - Torque wrench capable of 140 ft-lbs - Lug nut socket - Lug nut socket extension - Wheel lock key (I use standard lugs at the track, and wheel locks at home) - Racing tire pressure gauge - 12V DC-powered tire inflator - Temperature gun - Log book and pen+pencil - Empty SD card for PDR - Portable toolbox with your typical sockets, ratchets, box wrenches, etc. - Spare plastic boxes to store the random crap you take out of your car - Phone charger - Four jack stands (but no portable jack, I need to get one -- mine weighs 105 lbs!) --- PARTS/SUPPLIES --- - 2 quarts of spare 5W-40 dexos2 oil - 2 bottles of spare Motul RBF600 brake fluid (never needed to use this, but just in case) - Shop towels - One set of front brake pads (I run OEM, and they last me about 3 track days -- I don't use them if they have less than 1/3 of their thickness left -- I'll probably be on backing plates by the end of the day if I do that!) - One set of rear brake pads (I run OEM, they last me about 4 track days -- I don't use them if they have less than 1/4 of their thickness left) - Windshield cleaner - Bug/tar remover - Door numbers (magnetic) - Roll of TrakkTape (attempt to protect front bumper, rocker panels, and rear fenders from rock/rubber damage) No track day insurance. Never have purchased it in 10 years, I prefer to run my car at 9/10s of my ability and leave 1/10 for unforeseen situations. So far either I am lucky or simply good at avoiding incidents. I pretty rarely go 2+ wheels off, and have somehow NEVER spun my car on the track (only on autocross-like car control courses). Also, if you run at a place like Sonoma, the walls are enough of a deterrent from being a hero, track insurance or not..
2018 Camaro ZL1 1LE (Red Hot)
2002 BMW Spec E46 race car (Lizard Green) Previous cars: - 2018 Miata RF GT (Machine Gray/Auburn) - 2017 Camaro 1SS 1LE (Summit White) - 2008 BMW 135i (Montego Blue) - 1996 BMW 328i (Arctic Silver) |
01-24-2019, 08:57 PM | #17 |
Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2018
Thanks guys, I was already looking at Hagerty's for insurance and I don't think I ran across RLI yet but I'll check them out.
I've already flushed the transmission, differential and swapped in Motuls RBF 660. I also decided not to do the track alignment at this time. I daily this car alot and would rather wait to see how the car feels running on the track before I try the track alignment. I already got my tow hook set in but that is one tool I hope not to use down there.
2018 Camaro 1SS 1LE
01-25-2019, 06:25 AM | #18 |
Having seen the wear on the SC3 from track use even with a track alignment (someone else's car), I would be concerned that stock alignment could cause uneven wear issues at the outside of the tire under that kind of use.
01-27-2019, 05:48 PM | #19 |
Was that tire wear from 1 track session or mutliple track sessions?
I'm curious since I've seen on here some people do and some don't run the track alignment during track sessions.
2018 Camaro 1SS 1LE
01-27-2019, 07:04 PM | #20 |
He had multiple sessions on the tires. These tires seem to last a while, but my point was, if you are wearing the outside excessively due to an inadequate camber setting, you could cord it, while leaving some (now unusable) rubber on the inside of the tire. So the track alignment in my opinion is not just for better handling, it may also allow you to get more sessions in before having to buy new tires.
01-28-2019, 01:54 AM | #21 |
1LE Convert
I wouldn't track the car with the street alignment. OTOH, you do wear out the insides of the tires faster on the street with the track alignment.
I think going for near-zero toe is helpful. Maybe try an alignment that isn't full track alignment but isn't full street either.
01-28-2019, 07:07 AM | #22 | |
Drives: 2017 1le current /2015 2ss 1le sold Join Date: Jan 2016
2017 1LE Hyper Blue
01-28-2019, 06:05 PM | #23 |
Drives: '17 SS 1LE Join Date: Jan 2018
I'm at 4000 miles with one track day and my alignment is off. Took it to the dealer for warranty work and got told I have uneven wear on my front tires which is causing the slight pull. Outside of the track day I haven't really driven the car hard.
I knew we didn't get a lot of miles out of the stock tires but this is insane! |
01-30-2019, 09:48 AM | #24 |
Drives: 1LE Join Date: Sep 2017
ON TRACK IS CHEAPER THEN RLI. I had a friend throw his new c7z into the wall and they paid without hassles.
I am a licensed insurance agent by trade. |
01-30-2019, 02:39 PM | #25 | |
2017 1LE Hyper Blue
01-30-2019, 02:59 PM | #26 |
Drives: 2018 ZL1 coupe Join Date: Nov 2018
01-30-2019, 03:17 PM | #27 |
Drives: 17 SW 1LE Join Date: Jun 2017
^buy more than one event at a time
01-30-2019, 04:48 PM | #28 | |
Drives: 2018 1SS 1LE Join Date: Apr 2018
Mine's not daily driven, but have about 1,000 miles and 3 track days with a track alignment (-2.4* front -1.6 rear camber) and I haven't noticed any unusual wear on the inside edge.
2018 1SS 1LE (sold) |
