08-07-2018, 05:42 PM | #1 |
Drives: 2017 ZL1 Join Date: Jan 2018
Anyone added extra mufflers after their longtube header install?
I'm considering adding 2 resonators where the stock cats were, and also a Magnaflow "2 into 2" dual inlet/ outlet muffler in the rear, just before the rear differential. I had done this with my SS sedan and it's the only way in hell to make things civil when using longtubes, even with the stock NPP system.
08-07-2018, 06:04 PM | #2 |
Drives: ZL1/335i Join Date: Apr 2014
I think my car is more than acceptable with the valves closed in the stock muffler. I do have high flow cats, which probably helps. I feel like it would be way too quiet with an extra muffler. I’d do a set of resonators if you’re catless though.
08-07-2018, 06:32 PM | #3 | |
I should have specified that this question was directed towards catless headers. |
08-07-2018, 06:38 PM | #4 |
Drives: 2018 Camaro ZL1 Join Date: Feb 2018
I was JUST going to open a thread on this...lol.
With my OBX LT's, no cats and factory muffler, car sounds tinny and raspy. If I close the valves, the valves rattle. :( I think some resonators will fix the problem, but don't know what to go with. |
08-07-2018, 10:35 PM | #5 |
08-07-2018, 10:37 PM | #6 |
Drives: 2017 ZL1 Join Date: Jun 2012
08-07-2018, 11:12 PM | #7 |
It might help but won't take away the tinny and raspy sound. That's unfortunately how the ZL1 NPP seems to sound after adding Headers/no cats. All of the other GM cars sound good with just Headers/no cats or high flow cats but not a fan of how the 6th gen ZL1 sounds with that setup. If the resonators/extra muffler(s) doesn't fix it, then try a different axle-back/cat-back like Corsa or Borla. Borla gives you valves. Corsa gives you control with your foot. Corsa is only screaming loud at WOT or 80%+ throttle and when is any car with headers quiet with 80%+ throttle? Never.
08-08-2018, 04:42 AM | #8 | |
08-08-2018, 07:57 AM | #9 |
Drives: 2018 ZL1 Vert A10 Join Date: Jul 2017
I am LT's into Kooks full decat midpipe into stock NPP. I can't even hear the exhaust while cruising at 50mph, even with the roof down!
Are you sure you dont have your NPP set open all the time?
2018 ZL1 Vert - 854Whp / 791Wtq
2016 BRZ 2013 X5D 2005 STI 2001 2.5 RS Previous cars in chronological order 2016 GT350, 2014 MEV Rocket, 2013 Nissan Qashqai + 2, 1.6L Diesel, 2010 Nissan Note 1.5L Diesel, 2012 Dodge Ram 2500 6.7L Cummins, 2009 Subaru Impreza STI, 2005 Dodge Ram 1500, 2004 Mini Cooper S, 1997 Subaru Impreza Catalunya special Edition, 1992 Daihatsu Charade GTti, 1978 Mk1 Ford Fiesta |
08-08-2018, 08:48 AM | #10 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
nice to know for when i start my mods
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
08-08-2018, 09:13 AM | #11 | |
I like my setup better than Scott’s. He has LT’s into stock midpipe into a Corsa axle back. Sent from my iPhone using Tapatalk
08-08-2018, 09:28 AM | #12 |
I agree they make a difference in volume and tone. That’s one of the reasons I always try to run them if possible. I’d think a set of resonators in the spot where the cats/off road pipes go would produce a similar result.
08-08-2018, 10:15 AM | #13 |
Drives: 2017 Camaro 1SS M6 (SOLD) Join Date: Oct 2016
Not a ZL1 here, but a Whipple SS. I did cat delete pipes with all stock exhaust and HATED how it sounded, and it was embarrassingly loud. So I did the Borla ATAK system and added in their resonator in the mid-pipe, which is ceramic packed, so it wont over heat like the cats could. I am very happy with the exhaust now, and i am sure the resonator made a big difference.
Stock: 416hp/427tq, 12.21 @ 116.80 Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft. Tuned by EFX Tuning 688hp/632tq Best 1/4 to date: 10.705 @ 131.92 |
08-08-2018, 10:46 AM | #14 |
Drives: 2017 ZL1 Join Date: Mar 2014
When I eventually install cat-less long tube headers I intend to run dual x-pipes into the stock muffler to quell the extra noise.
