11-13-2019, 11:16 AM | #169 |
Some good numbers Steve and great mph but man to have the motor expire is very bad news. Sorry to here that and I had that problem last year and it sucks to have to lay out the bucks to fix it.
11-13-2019, 03:57 PM | #170 |
Drives: 2018 Camaro ZL1 Join Date: Dec 2017
It’s ok. I knew i was at the upper limits of the motor. sucks
11-30-2019, 08:01 AM | #171 |
If anyone is interested, I may sell the car as is with every spare part i have. My garage is on hold because the assembly crew doesn't come to NY in the winter. They are from NC and told me that AFTER i placed the order. I wont be able to take the car apart until spring. My new car is going to the chassis shop in January and I kind of want to focus on that. Worst case scenario, my car needs a short block ($6000) Best case it has 1 bent rod. Still runs, just noisy lol and has 39 pounds of oil pressure. If it doesn't sell, i'll put a short block in it next spring.
Heres a rundown 2018 with 78xx miles. Kong performance 2650 blower Kong performance 112mm Tb Crawford racing CR fueler port injection with Holley HP ecu and 1300cc injectors Fore triple 450 intank fuel system -10 feed -8 return Frankenstein Ported heads Texas Speed Roller Rockers Cam Motion LTMax cam 2” Stainless works headers 7 Gallon ice tank with Stewart EMP pump BMR/Carlyle 15” conversion BMR Driveshaft Loop BMR Front Springs DSS chromoly driveshaft DSS 1400hp axles (not installed) Carbon ceramic front brakes (C7 Z06 with ZL1 Hats) Magnaflow Axle back Chevrolet performance full Drag pack Weld 15” S77 bead lock rears Spare 10L90 with 488 miles Spare Brand new diff Spare stainless works axle back. Probably more that I’m forgetting |
12-02-2019, 12:32 AM | #172 |
Drives: 2017 ZL1 A10 Join Date: Aug 2016
Well that sucks. I am kind of going through the same thing after the front snout on the stock crank snapped off on mine and ate some valves when the cam stopped turning. Stock blower too... Oh well, engine is out and is going to be built while I am stuck in the sand box on deployment.
I have a question for you though, did the BMR motor mounts drop the engine enough to reduce the trimming needed for the Edelbrock 2650? I am going to run port injection as well to get away from using so much meth, but that precludes using the Magnusen 2650 as it does not appear to be compatible with port injection. Thanks, and the bad luck sucks doesn't it? |
12-02-2019, 08:37 PM | #173 | |
12-02-2019, 10:18 PM | #174 |
I have the BMR mounts and it didn't change anything on engine placement. Cleared my headers and made more room to work underneath if needed.
12-03-2019, 10:05 AM | #175 | |
Drives: 2018 ZL1 Coupe NFG M6 Join Date: May 2017
Power level? Mods? Did it break while racing?
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School 2017 Colorado Z71 <- Daily 2018 ZL1 M6 <- Not Daily |
12-03-2019, 10:58 AM | #176 | |
Anyway, back to the scheduled program lol. |
12-03-2019, 11:46 AM | #177 |
Wow, that is freak! Thank you for sharing that. Wonder if the belt was freakishly tight or something...
12-03-2019, 11:58 AM | #178 |
Same belt for 18k plus miles..? Who knows right?
01-13-2020, 07:40 AM | #179 |
Ok so I pulled the motor Saturday. It’s a bent rod in cylinder 7. The bottom of the piston was in contact with the counterweight on the crank. So now I’m stuck trying to make a decision. Since I am building a new race car, should I focus on that or beef up this block and continue. So while I and deciding, the blower, fuel system, port injection are all for sale. If no one is interested, the block will be beefed up and back in the car.
01-13-2020, 08:36 AM | #180 | |
Drives: 2017 ZL1 Join Date: Jun 2018
Kooks full exhaust, Roto Fab, Whipple,Williams 103, Fore innovation, JRE cam and tuning
01-13-2020, 09:57 AM | #181 |
I would rather sell it as 1 complete kit. Can’t use the blower with out the port injection and can’t use port injection without the fuel system. If someone is interested in the other 2 without the fuel system then I will separate it.
01-13-2020, 01:18 PM | #182 |
NP let me know. Thanks
