06-23-2017, 07:00 PM | #29 |
Drives: A10 LT4 Join Date: Aug 2016
OK...picked up a Proto wrench. Yeah, I'm a Snap-On guy but the company I work for is a disty for Proto & got it at cost. Big savings over the top shelf as little as I am going to use it. They do make good tools however.
Anyway, I got that scratch on the rim & got it fixed, but obviously they didn't torque. My question is did any of you guys check your torque on these lugs when bought new...would you suggest just checking them all at the 135 - 140 range. Did you notice if they were or weren't to to spec?? Just curious. |
06-23-2017, 07:14 PM | #30 | |
I love crepes
06-23-2017, 07:22 PM | #31 |
Not mine...set the wrench to 135lbs.
On each wheel, only one or two lugs went straight to the click...all the others went about 1/2 turn or more before reaching. All 4 safety/key lugs were under 135...just fyi for those that may want to check before attending any track days. FWIW fellas... |
06-23-2017, 08:54 PM | #32 |
Drives: Duramax Join Date: May 2017
06-23-2017, 11:47 PM | #33 | |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
Funny how the 5th Gen's list 110lbs for torque.....
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
06-24-2017, 09:03 AM | #34 | |
Drives: 2019 Silverado Z71 6.2L A10 Join Date: Mar 2017
https://www.amazon.com/Stanley-J6014...+torque+wrench
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's. Past Rides 2017 M6 Camaro ZL1 Hyper Blue 2016 M6 GT350 White with blue strips 2014 M6 Mustang GT Premium Track Pack Ruby Red 2012 M6 M3 Melbourne Red Metallic |
06-24-2017, 09:36 AM | #35 | |
Yes sir...that is the one. I paid a little less, but that is a very fair price.
Stanley - Black & Decker is strong & has snagged the majority of the hand tool market with their various brands / acquisitions. It's a good wrench & just couldn't see paying twice as much for Snap-on. The shop had this one in stock from 50-250lbs & a 30-150lbs unit. Like jerome stated, I was trying to keep the needs in the middle & and not use it on the extreme ends. I also want to check out the front sway bar torque since so many are having issues with the clunk. Sorta on the down range of my wrench as my understanding is 89lbs on the lower & 74lbs on the upper sway. I mentioned to the shop manager that I also needed him to order torque screwdriver for my long gun / optic mounts. He walked away & pulled a Proto 6106 unit. Said it had been sitting on the shelf for over a year & gifted it to me. I'll also likely pick up lower range torque 3/8 drive down the road...like stated, you really do need these from time to time & make a good addition to the 'box'. Quote:
02-16-2018, 02:03 AM | #36 | |
Drives: 2018 Camaro SS 1LE Join Date: Oct 2017
02-21-2018, 05:07 PM | #37 |
Bring It
Possibly a dumb question. That’s fine. But what determines the torque spec of the lugs? Is it the lugs themselves, thread pattern, the wheels, other? Just wondering what I need to adjust if I replace any of the above. Thanks.
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold 2010 Camaro SS - 650RWHP Daily Driver - Traded |
02-21-2018, 05:23 PM | #38 |
Drives: 2013 ZL1 and 2019 Ram Laramie Join Date: May 2017
None of the above...really, although they are ancillary.
The answer: make, model and year. Although stud size obviously limits torque. For those wanting a simple way to install and remove lugnuts: I haven't looked back since getting my M18 Gen 2 impact wrench. Removes up to 1400 lbs. Real useful on 3/4" studs (torqued to 450-500 ft. lbs.). |
02-22-2018, 12:08 AM | #39 |
I went around and noticed that one of my wheels was not at 140 and needed a 3/4 turn to hit 140lb. Really weird, only 3kmiles on her.
02-22-2018, 06:39 AM | #40 | |
Bring It
Interesting. I wouldn’t have expected that. Wasn’t the the bolt pattern and such the same from the 5th gen which didn’t require 140? So if I moved wheels over and hardware potentially (not certain that’s the same), that alone requiring more torque is hard to comprehend. Do impact wrenches have a tightening torque spec listed? I didn’t see one on mine and wasn’t sure if it would strip something if I used it to tighten. Supposed to use manual wrench to tighten right? I have an Aircat 1000-TH.
02-22-2018, 11:25 AM | #41 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
I wouldn't use an impact wrench to tighten to final spec. It'd be a time saver to torque below spec with an impact set on a lower setting, but final spec should be done by a calibrated torque wrench. This is why I always ask how they torque the tires at tire shops, and I check them when I get home. Many times I've had lug nuts applied to about 140 ft lbs on my daily driver, when the spec is 80. This would be a huge problem if I had a flat and needed to use the factory wrench to remove the nuts.
02-22-2018, 12:02 PM | #42 | |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
If you prefer, you can buy one calibrated for just under your torque spec (they normally come in 10 ft/lb increments), then after using the torque wrench, tighten the lug nuts with your own torque wrench. For display purposes only so you can see what I'm talking about (choose your own brand!) https://www.harborfreight.com/10-pie...set-69870.html Using a torque stick with an impact wrench makes torqueing the lug nuts much faster and with no worry that your new impact wrench will tighten them so much nobody will be able to get them off. |
